Thread: 1970 Pontiac Rear End
Results 1 to 6 of 6
  1. #1 1970 Pontiac Rear End
    Apr 2009
    Mesquite, Texas
    Hello everyone ! I am changing out my rear end and need help identifing the technical name for the bushings that sit above the pumpkin cover. My local parts stores don't seem to have them or can't identify them correctly.
    Secondly I'm trying to identify the gear ration on the replacement rear end. The only stamp available is 9795082 and E289. Rear end is out of a 70 Pontiac Grand Prix. Any help would be greatly appreciated.
    Thanks
    sfgreen
  2. #2 Re: 1970 Pontiac Rear End
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    get me a pic of the rear end housing, If its a control arm like the chevelles were then its a upper control arm bushing for either right or left rear.
    The gear ratio thing I know by counting how many times the tire rotates to the rotation of the drive shaft or yoke if no DS is hooked up.
    Mark the tire and body, then mark the diff housing and the yoke, easier to count this way.
    So for every 3 full rotations of the tire, the yoke should spin 23 full rotations as well. ratio = 3.23 as an example.
  3. #3 Re: 1970 Pontiac Rear End
    Apr 2009
    Mesquite, Texas
    Here's a picture of the rear end with the bushings out.
    1970 Pontiac Rear End Attached Images
  4. #4 Re: 1970 Pontiac Rear End
    Aug 2008
    60118 NE Illinois
    rear upper control arm bushings, get some poly or prothanes. I used the prothanes after the poly, a little softer but not by much.
    I have had many classics and my last one was a 78 mino with the same rear end in it. they are easy as pie to be honest.
  5. #5 Re: 1970 Pontiac Rear End
    Apr 2009
    Mesquite, Texas
    Thanks for all your help.. I really appreciate it.
    sfgreen
  6. #6 Re: 1970 Pontiac Rear End
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Prothanes are much nicer than the poly
    My EX wifes other car is a broom.
  1. RIP Pontiac
    By Ralphie in forum The Rant Forum
    Last Post: 05-13-2009, 11:24 AM
  2. Pontiac GTX
    By Snow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2008, 11:13 AM
  3. 2000 Pontiac SE :)
    By 2000segp in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 11:07 AM
  4. My Pontiac GTP Poem
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 04-18-2008, 06:28 PM
  5. New to pontiac
    By Hca-Bronco in forum Introductions/Noob Questions
    Last Post: 03-18-2008, 08:33 PM
