Thread: 180 tstat question
Results 1 to 17 of 17
  1. #1 180 tstat question
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Hey guys. Well about 2 weeks ago I put in my 180 tstat. I did everything I was supposed to. It got up to temp and cooled down just fine this whole time. Now just today I was drivin around and in traffic it got up to like 200 plus and I don't know why. Fans r kickin on, no leaks and got plenty of coolant. I just wander if I got a crappy tstat or what. And can u screw up how that o ring goes back on? Was gonna fiddle with it tomorrow but thought I'd ask
  2. #2 Re: 180 tstat question
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    i
    hope u bleed the cooling system. i drilled 2 small holes (3/32nd) also.
  3. #3 Re: 180 tstat question
    Apr 2009
    shawnee, kansas
    Yup. Sure did. And like I said it rand fine for the last two weeks. Just kinda caught me off gaurd. What do u mean drilled two holes?
  4. #4 Re: 180 tstat question
    Don't drill holes in the thermostat, just leave it alone IMO. It does it's job just fine. I would pull it off and see if there are any issues with the o-ring around it. check the coolant level too (take off the radiator cap, not just the overflow tank).
    That PCM of mine will turn your fans on sooner and keep it cooler
  5. #5 Re: 180 tstat question
    Apr 2009
    shawnee, kansas
    Well the coolant level is good and I think I'm just gonna pull it off tomorrow and see what's up. Can u put that oring on wrong? And hey bluegtp91 ill give u a call tomorrow and see about comin to get that pcm. Can't wait to put it in
  6. #6 Re: 180 tstat question
    Barksdale AFB, LA
    It's gonna warm up in traffic when you're not moving. Warmer air with all the other cars around has an effect too. It's normal.
    2009 Subaru Impreza WRX STI
  7. #7 Re: 180 tstat question
    IF...you don't like it sitting as high as it does you can always get a 160* during the summer-time...just an option
  8. #8 Re: 180 tstat question
    no one ever needs a 160* thermostat...ever...
  9. #9 Re: 180 tstat question
    Apr 2009
    shawnee, kansas
    Well yeah but even with a stock tstat it never got that warm. Why would it with a lower one?
  10. #10 Re: 180 tstat question
    Air in the system? You might have a air pocket moving around in there just a thought...
  11. #11 Re: 180 tstat question
    Apr 2009
    shawnee, kansas
    Yeah I don't think its an air pocket. I just bled it yesterday
  12. #12 Re: 180 tstat question
    Well I've come to the conclusion it is the stock PCM and you need to get mine MUAHAHAHAHAHA!! lol
  13. #13 Re: 180 tstat question
    SE Level Member BiggRiggs's Avatar
    Feb 2009
    Altoona, PA
    If you still have the stock pcm settings for the fan turn on points, then they don't come on until a bit over 200* (212* I think).
    When you're not moving, there will be no air going through the radiator to cool down the hot coolant being pumped through it.
    When I installed a 180* t-stat, it did the exact same thing.
    I installed it a few days before I had a guy come over to do a tune and I had asked him to set the fan turn on points for the 180* t-stat.
    It still went up to about 212* while driving through the city before it cooled back down again.
    I figured out later that the guy forgot to actually change the fan settings while doing the tune. Go figure.
    Now I have the fan turn on points set to 180* and my ECT's don't go over 185*.
    Also, sometimes a pesky air bubble can be a bit persistant.
    I've had to bleed the air out multiple times before.
    One time I just kept a 7mm socket and a towel in my car for about a week and opened the valve above the t-stat every time I parked my car.
    -Riggs.
    2004 Monte Carlo SS
    Intimidator edition #3470/4000
  14. #14 Re: 180 tstat question
    SE Level Member DC1263's Avatar
    Nov 2008
    Middlesex, NC
    The thermostat is much maligned, often misunderstood, and seldom credited for its mostly reliable service.
    Thermostats in proper working order, control only the minimum operating temperature at which engine coolant is allowed to heat. A properly operating thermostat has absolutely nothing to do with how hot the engine becomes. If you are experiencing an over heating engine, changing to a colder thermostat will not correct the condition, it only allows the coolant more time to over heat. A thermostat once fully open can do no more to control temperature. The overheating cause lays somewhere else.
    Some believe that removing the thermostat completely can remedy over heating concerns. This can be deceiving, with out some flow control coolant can pass through the radiator without slowing enough to cool, returning to the engine hotter with each circuit of the liquid.
    The temperature stamped or marked on the thermostat is the "start to open" rating. This is often referred to as when the thermostat just "cracks open" and allows some coolant to flow. This is in contrast to the popular belief that the temperature specification identifies when the thermostat is fully open. Most applications have a thermostat that is designed to "crack" at about 180 to 195 degrees F. If the thermostat opening is set too low or too high engine damage can be the result. High coolant temperatures can cause abnormal combustion, loss of power, damage to bearings and other moving parts, etc. Low engine operating temperatures lead to excessive fuel consumption, dilution of lubricating oil by the addition of unburned fuel, the formation of sludge from the condensation of water in the crankcase along with a host of other concerns.
    Most thermostats are designed to be fully open 20 degrees F after cracking. So 215' on a 195' would be considered "Normal"
    As would 200' on a 180'
    "The First Step In Successful Troubleshooting Is Eliminating The User As The Source Of The Problem"
    2006_Grand Prix_Liquid Silver Metallic_Black Leather_3.8_192,000
  15. #15 Re: 180 tstat question
    Water Pump.
  16. #16 Re: 180 tstat question
    Apr 2009
    shawnee, kansas
    Well I don't think that anything is wrong with my cooling system. I mean while I'm driving it runs great so its gotta be workin. Just when I sit still does it get warm. And really it never goes over 200. So I guess I'm just borrowing trouble. Thanks to everyone for the input especially you biggriggs. I'm gonna try the pcm upgrade. Should work well
  17. #17 Re: 180 tstat question
    Dec 2008
    hueytown, alabama
    some sa thatdrilling 1 or2 small holes helps keep a constant temp. some will say it doesn't do anything, but who knows. i've done it for the past 22 yrs so maybe someone will disprove or prove it. the pcm will do u good as far as the fan settings and also the transmission upgrades. opinio ns are like assholes, everybody has one!
  1. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  2. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
  3. 180 tstat drilled or not drilled?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 04:04 PM
  4. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
