Thread: Power Steering Issue
Results 1 to 8 of 8
  1. #1 Power Steering Issue
    CT
    My power steering is fine unless I take a sharp turn under some speed. Then when I turn the wheel to the left or right it makes this whiring (yeah great way to describe it) sound and it harder to turn. I was going to check to the power steering but where the hell is the cap to check it lol.
  2. #2 Re: Power Steering Issue
    Guam
    Yeah check it now.
    The PS pump is in the left, or passenger side of the engine, and to the back. You have to lean over the engine and look down, since it is behind the downward.
  3. #3 Re: Power Steering Issue
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    you have to lean over the front passenger panel and look at the alternator. my gess is that it is covered in dirt and stuff( mine was) and what you do is look at the alternator and then look down between the alt and the fire wall. its round and has a steering wheel on it if i remember correctly. i recommend buying a funnel with a bending hose on it. it will make ur life tons easier
    silver 2003 Grand Prix GT List is on it's way to be updated
  4. #4 Re: Power Steering Issue
    GT Level Member skidoojames151's Avatar
    seattle
    my car did this too when it was low on fluid...no problems since i added lucas power stering conditioner
  5. #5 Re: Power Steering Issue
    CT
    Well that makes sense as to why I couldn't find it. I'll take a look this friday.
  6. #6 Re: Power Steering Issue
    You do also know that with magna steer...it makes the steering harder at speeds so you don't steer too easy and crash like a noob.
    As for the whirring.. yeah, fluid level.
  7. #7 Re: Power Steering Issue
    CT
    Ah well its not hard unless I took a turn and its not making that noise. Probably getting air in it and take some time to get the air out. I'll have to check the level.
  8. #8 Re: Power Steering Issue
    Nov 2009
    Joplin MO
    I have an 06 grand prix super charged and it is really hard to turn to the left it turns really easy to the right, the fluid level is good what should i do?
  1. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  2. power steering
    Last Post: 04-11-2009, 10:52 PM
  3. Power Steering Issue?
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 04:09 PM
  4. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
