Thread: New Here, Fuel Mileage
Results 1 to 19 of 19
  1. #1 New Here, Fuel Mileage
    SE Level Member cowmilker08's Avatar
    Kendallville, IN
    What kind of mileage should my fiance's '97 GP GT get on the highway,? It has 107k miles on the clock.
  2. #2 Re: New Here, Fuel Mileage
    if it is in good running condition maybe in the higher 20s? if not, 18-22 like i get.
  3. #3 Re: New Here, Fuel Mileage
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    26-27 mpg
  4. #4 Re: New Here, Fuel Mileage
    Kendallville, IN
    well when she drives it for the majority of a tank its usually 18mpg but if i drive it for the majority of a tank its about 21. it seems to run very well.
    Edit: Last summer when it didn't see many highway miles it was only getting about 15-16mpg!
  5. #5 Re: New Here, Fuel Mileage
  6. #6 Re: New Here, Fuel Mileage
    GTP Level Member dstout's Avatar
    ky
    Most of the time I get between 18 and 24 but it depends on how I feel sometimes it's less than that.
  7. #7 Re: New Here, Fuel Mileage
    Dec 2008
    Long Island, NY
    god damn i have a 97 gp with 142,xxx and i get about 10 mpg around town. 155 miles before i have to fill it up again
  8. #8 Re: New Here, Fuel Mileage
    Quote Originally Posted by Nick22 View Post
    that is super low and i bet something is wrong with your car and needs to be replaced.
  9. #9 Re: New Here, Fuel Mileage
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    '00 GP SE here with a '97 Monte Carlo 3100 (3.1L) engine which was totally rebuilt.
    I average between 27-36mpg depending on how I accelerate / how much city driving I do. I can get between 380-500 miles per tank. (500 miles is strictly freeway driving).
    I knew I had a bad O2 sensor last week because my fuel economy dropped to 14 MPG. As soon as I replaced it, I'm right back at 28.9 MPG.
    As for your bad gas mileage, are you getting a SES light?
    If not, how old are/how are the condition of the following items: Air filter, fuel filter, PCV valve, EGR valve, O2 sensor(s)?
  10. #10 Re: New Here, Fuel Mileage
    Kendallville, IN
    Well i'm new to this car, and as far i know the only maintance that gets done to it is the yearly oil change. Yes i tell her that isn't often enough, but ya know. How bad is it to change the O2 sensor(s)? I'm more of a diesel guy so bare with me. (I pefer a MAP to an O2 lol)
  11. #11 Re: New Here, Fuel Mileage
    Kendallville, IN
    well fiance says that a sensor was changed a while back becuase the car kept dying, i checked the air filter early last fall and it looked so i blew it out with an air hose, and put it back. how can i tell if the PCV valve or EGR valve is plugged/malfunctioning? If the fuel filter needs changed how do i do it on this car?
    1997 Grand Prix GT 118,000 miles - Stock (fiance's)
    1996 Ford F-250 HD 7.3L Powerstroke Turbo Diesel , 3 1/2" Straight Pipe Exhaust, K&N air filter (soon to go), 203 degree T-stat, Torque Converter Lock-up Switch + Exhaust Back Pressure Valve Switch = Exhaust Brake , 243,000 miles
  12. #12 Re: New Here, Fuel Mileage
    Cowtown, OH
    The PCV is plugged in on the top of the engine... It is a cheap part (3-7$) and plugs into a hose on one end and the valve cover on the other... it acts as a vacuum regulator to keep the pressure on the top end of the engine correct in comparison to the intake.
    As for the EGR... you would more than likely have a SES light... And the car would choke out due to exhaust backing up in the exhaust headers.
  13. #13 Re: New Here, Fuel Mileage
    Kendallville, IN
    well no light so the poor mileage could be cuased by the PCV valve or O2 sensor? What about the possibility of the CAT getting plugged, What signs would that show?
    I'd kinda like to know why last summer my truck got better fuel mileage than the car. LOL, she blows alot of smoke when i get on it so the car should be doin' way better than the truck.
  14. #14 Re: New Here, Fuel Mileage
    ky
    You should clean the MAF sensor, I cleaned mine and it helped with my mileage. Just a thought. You might want to run some Seafoam through it too to clean out some of the carbon and crap. If you do decide to do Seafoam you will have to change the oil and prob. the spark plugs too. Those things will help some.
  15. #15 Re: New Here, Fuel Mileage
    GT Level Member chad27's Avatar
    Apr 2009
    gpt,ms
    Mine is between 19.6- 20.7 city
  16. #16 Re: New Here, Fuel Mileage
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    I get almost 21 MPG on combined driving, my wife has gotten over 30 MPG in hers with just freeway driving.
  1. The alt rewire mod actually DOES increase fuel mileage!!
    By DanGTP in forum General Tech Discussion
    Last Post: 04-12-2012, 07:31 AM
  2. Fuel Mileage
    By Scheer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 10:57 PM
  3. Need better gas mileage
    By bayareagtp in forum Off Topic Discussion
    Last Post: 12-02-2008, 12:40 AM
  4. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
