Thread: Remote start on GP
Results 1 to 18 of 18
Freebeer187 Remote start on GP 10-17-2008, 12:07 PM
Toofastgs Re: Remote start on GP 10-17-2008, 12:23 PM
Freebeer187 Re: Remote start on GP 10-17-2008, 12:31 PM
kyle99gtp Re: Remote start on GP 10-17-2008, 12:33 PM
Freebeer187 Re: Remote start on GP 10-17-2008, 12:37 PM
Toofastgs Re: Remote start on GP 10-17-2008, 12:42 PM
Freebeer187 Re: Remote start on GP 10-17-2008, 12:51 PM
Toofastgs Re: Remote start on GP 10-17-2008, 03:59 PM
Freebeer187 Re: Remote start on GP 10-17-2008, 04:42 PM
gp04duff Re: Remote start on GP 12-01-2008, 07:19 AM
crywolf Re: Remote start on GP 12-02-2008, 12:55 PM
gp04duff Re: Remote start on GP 12-03-2008, 10:32 AM
crywolf Re: Remote start on GP 12-03-2008, 02:39 PM
jasonball Re: Remote start on GP 12-03-2008, 02:42 PM
BigG Re: Remote start on GP 12-04-2008, 12:33 AM
gp04duff Re: Remote start on GP 12-04-2008, 01:22 AM
kjohnson Re: Remote start on GP 04-12-2009, 05:49 PM
dstout Re: Remote start on GP 04-12-2009, 07:30 PM
  1. #1 Remote start on GP
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I am planning on getting remote start in my 01 GTP since the winter is coming and remote start is a great convenience.
    Anyway I remember a while back when I had my Camaro I called a few places and they quoted me around 200 for a remote start setup.
    What do you guys suggest I do? I was a little worried that I would go through them and I would get some cheapo setup (cheap remote). Maby I should purchase the kit and have someone install it for me?
    Are there any setups you recommend? Maby a east DIY setup?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Remote start on GP
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Go to a well known place for good installs.
    Prices can be from 200+ depending on features like if you want alarm and keyless entry with it. How far you want to be able to start car. If you want 2way communication from car to remote
    Id stick with viper, Python, compustar i think is another good brand.
    Python – Security with Remote Start - Python 990 is what i have. What cant it do LOL.
    Also keep in mind. Even the best alarm is only as good as the install. Have a bad installer installing top of line alarm it can perform like a ****
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Remote start on GP
    Bartlett, IL
    Thanks for the info. I do NOT want an alarm. When I bought that trans am it had a CRAZY alarm in it. Even after i pulled out the brain the car would still go off. I had no idea how to work it...
    I would just like a simple remote start.
    How hard are they to install?
    How To: E-Brake Pwn
  4. #4 Re: Remote start on GP
    NE Ohio
    theres lot of wiring and splicing involved...i got one for chirstmas last year and ive yet to install it.
    get the bulldog remote start wring adapter thing, that makes it a little easier.
  5. #5 Re: Remote start on GP
    Bartlett, IL
    Im thinking im going to have it installed profesionally.
    I called this place and they said 200 even. All the brand names are weird though. There called "Auto Start" and stuff like that...
    They say there good stuff... (though i dont expect them to say its bad)
    How To: E-Brake Pwn
  6. #6 Re: Remote start on GP
    Tulsa, Ok
    I would not go cheap brands. Quality unknown and what happens if it fails will they be around to help?
    viper, python (DEI) will they will cover it with a lifetime warranty
    98' GS - Sold
  7. #7 Re: Remote start on GP
    Bartlett, IL
    Viper is good sheet
    How To: E-Brake Pwn
  8. #8 Re: Remote start on GP
    Tulsa, Ok
    They are.
    Viper and Python are the same alarm system. Only difference is the icon on the brain and the casing of the remote. Screen on remote is the same and all electronics are the same.
    Also you will need a key bypass. Think it is a 555u and a spare key for it to bypass passkey
    98' GS - Sold
  9. #9 Re: Remote start on GP
    Bartlett, IL
    So I need to have a spare key that would be used for ignition, and it will have to be installed in the brain?
    I have a spare key, but I would like to keep it for emergencies. If this is the case, how would i get another spare?
    Is it possible to get a copy fabricated at a lock smith or maby even wal mart?
    EDIT*
    After re reading what you posted, it doesnt sound like a need a new key. It sounds like I need extra hardware? Im thinking of at least taking a look at the shop that would install the setup for $200. I know its the best of stuff, but maby it will do the trick... Hopefully he would have everything I need
    How To: E-Brake Pwn
  10. #10 Re: Remote start on GP
    Dec 2008
    revere
    go to your local gm dealer show them your registration and they will make you a new pk3. It costs 40 dollars.
  11. #11 Re: Remote start on GP
    Nov 2008
    Cedar Rapids, IA
    just go to a hardware store and pay like $2 for a key copy. They basically insert that key into a fake ignition source that is wired in under your dash to enable your car to start. It is simply to bypass your factory security measures.
  12. #12 Re: Remote start on GP
    Dec 2008
    revere
    You dont want to bypass your security system. By doing so you are taking one of the best safety measures for car theft ever out of the equation. Without the pk3 system you can steal the car like it was the 1970's. The pk3 system has chip inside that has to match the one in car. If it is not present the car will not start.
  13. #13 Re: Remote start on GP
    Nov 2008
    Cedar Rapids, IA
    Right, I'm not saying you're disabling the security system, you must simply "bypass" security in order for the car to start. With out this when the car starts it will immediately die and the alarm will prolly go off as I'm sure you know. Just wanted to clarify
  14. #14 Re: Remote start on GP
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    remote start wasn't an option for grand prixs? I got one on my G6.
  15. #15 Re: Remote start on GP
    SE Level Member BigG's Avatar
    St. Louis
    My 98 GTP has a Python alarm, with remote start. It was about 500$, installed. 200$, for just a remote start, sounds about average.
  16. #16 Re: Remote start on GP
    Dec 2008
    revere
    Yes cry WOLF is right. I misunderstood what he meant. you need 556uw bypass. This wil "bypass" the system for remote start, open the fuel rails and then return he car to regular security...you will also need to put a loop on the ignition or the SERVICE THEFT SYSTEM light will come on. The way you reset the that light is turn the key to the on position 7 times and on the eighth start the engine.
  17. #17 Re: Remote start on GP
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    so really unless you want a super nice alarm your better off just using a remote start right? and is there a way to only have one remote but still be able control both? im really just talking about still starting it plus retaining the light flash and horn feature
    thanks guys in advance
    silver 2003 Grand Prix GT List is on it's way to be updated
  18. #18 Re: Remote start on GP
    GTP Level Member dstout's Avatar
    ky
    I use to have a remote start and what the are saying about the pk3 is correct but something happened with mine where the theft deterent module kept burning out and when that happened the fuel pump would shut down. The car would run for a few seconds and die, that is part of the security system. So find a good intall shop and you should be alright.
  1. Remote start options
    By xerxescct in forum General Tech Discussion
    Last Post: 10-31-2009, 08:14 AM
  2. PK III and Remote start...auto shut down grrr
    By mongo in forum General Tech Discussion
    Last Post: 08-07-2008, 06:37 PM
  3. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
  4. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
  5. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
