Thread: GXP best front tires??
Results 1 to 13 of 13
  1. #1 GXP best front tires??
    Apr 2009
    Joliet
    Hi, has anyone had any experience with upgrading their front tires? I am looking at getting a super sticky tire on the car. I see Mickey Thompson has a model of drag tire that would work, but I haven't met anyone that has tried them yet. Any input would be great. I am looking to hook up better, and stay hooked up.
  2. #2 Re: GXP best front tires??
    this is FWD...even with a slick you cant just slam the pedal to the floor.
  3. #3 Re: GXP best front tires??
    Apr 2009
    Joliet
    Thanks, I know you can't just slam the gas... But I would like some tires that grip better so I can put the pedal down a little farther, and then once the NOS hits, the car won't spin quite as bad. I'm not looking for a miracle, just a little help with traction.
  4. #4 Re: GXP best front tires??
  5. #5 Re: GXP best front tires??
    Apr 2009
    CT
    falken azenis 615
    /end thread
  6. #6 Re: GXP best front tires??
    Apr 2009
    Joliet
    I'm looking for street.
  7. #7 Re: GXP best front tires??
    Apr 2009
    Joliet
    Thanks, those falkens look like a canidate.
  8. #8 Re: GXP best front tires??
    Moore, Oklahoma
    Honestly, if you're making any kind of power on a FWD car, its pretty safe to say that you're not going to find a GOOD traction street tire for a FWD, RWD is a different story. They only way you might get half assed traction on the street is running DRs or Slicks all the time and let me tell ya, thats going to be miserable.
    I'd give up now on this idea and pick up a spare set of rims and get you some DRs or Slicks. Throw em on when you're at the track or when you want to play. Heat em up and go.
    Believe me, i've done the research even had a set of supposedly good sticky street tire. Don't waste your time or money. You'll never hook like a RWD car...
    Shawn W. Larsen
  9. #9 Re: GXP best front tires??
    Apr 2009
    Joliet
    Thanks, I appreciate your help
  10. #10 Re: GXP best front tires??
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    I know a guy that uses nitto 555R's on his cobalt...check them out.
    They are ok for a street car. Not the best in the rain, but better than any slick or any other drag radial and they last longer than most drag radials...
    Hell, it's what I use on my camaro, but they are 315s!
  11. #11 Re: GXP best front tires??
    Moore, Oklahoma
    Quote Originally Posted by Z28 View Post
    I've heard more GTP owners on ClubGP ***** about how bad the 555R hooked on the street than any other tires. Most if not all said they wouldn't buy them again.
    Unless you wanna run a good DR or Slick on the street, your not going to hook with these cars, i'm sorry.
    Shawn W. Larsen
  12. #12 Re: GXP best front tires??
    Oct 2008
    Omaha, NE
    All depends on how you use them..what psi you run, how much you heat them up and most of all suspension. It can be a tricky tire, but it's been proven to get 1.6 60' but usually more around 1.7-1.8'.
    FWD...hell idk what to tell ya. i can't count all the people i know running these
  13. #13 Re: GXP best front tires??
    Donating Users blowfishRus6's Avatar
    g.a.
    nitto's do like to be heated up before they hook good. cant always do that on the street tho.
    bfg's were pretty good for me, im gonna try some dunlops next.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. I think I need new tires...
    By SlowM90 in forum Tires & Wheels
    Last Post: 04-06-2009, 07:45 AM
  2. Tires
    By offroadfury6 in forum Tires & Wheels
    Last Post: 10-02-2008, 12:36 PM
  3. New Tires
    By spidamanSS in forum Tires & Wheels
    Last Post: 09-02-2008, 01:03 AM
  4. What tires do you run???
    By suprchrgd in forum Tires & Wheels
    Last Post: 04-15-2008, 12:18 PM
