Thread: 99 pontiac grand prix gtp
Results 1 to 5 of 5
  1. #1 99 pontiac grand prix gtp
    virginia
    i have a 1999 pontiac gtp i can not get the gas gauge to work ive put 2 fuel pumps/sending units in it along with another gauge cluster! still wont work. when i turn the key on it goes to full then falls to empty. Any help would be greatly appreciated thanks!!
  2. #2 Re: 99 pontiac grand prix gtp
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    The gauge is wired through the PCM and I have seen the wiring bad and the PCM not reading it right If you can put in another PCM and see if that changes it. Good Luck
  3. #3 Re: 99 pontiac grand prix gtp
    Willoughby, Ohio
    wow, i guess replacing the PCM is the last option... hope that works
  4. #4 Re: 99 pontiac grand prix gtp
    virginia
    The guy i bought this from had got a fuel pump for it because the orignal one went bad. So he bought a fuel pump/ sending unit offline for some reason they sent him 2. now the gauge doesnt work. I just cant belive that both sending units are bad ? When it was working before the orignal went bad. Thanks
  5. #5 Re: 99 pontiac grand prix gtp
    GTP Level Member SuperSport's Avatar
    Michigan
    Were the 2 sending units you bought new? Because if you bought them used, they might be as bad as your first one. It is a common problem for the sending units in these cars to go bad.
    I had this same problem. Bought a new sending unit and fixed the problem.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. New member and first time Pontiac Grand Prix owner (first pontiac ever)
    By Lexiconix in forum Introductions/Noob Questions
    Last Post: 11-10-2010, 09:45 PM
  2. My Pontiac Grand Prix GTP
    By fremmy182 in forum Visual/Body Modifications
    Last Post: 10-04-2010, 08:03 PM
  3. 08 pontiac grand prix d.i.c.
    By khunter0111 in forum General Tech Discussion
    Last Post: 08-05-2010, 10:47 AM
  4. Not Grand Prix but still Pontiac
    By yutzybrian in forum Introductions/Noob Questions
    Last Post: 04-12-2010, 09:01 AM
