Thread: no reverse lights and trunk popper don't work
Results 1 to 9 of 9
  1. #1 no reverse lights and trunk popper don't work
    SE Level Member frankdatank0's Avatar
    Dec 2008
    Manhattan, KS
    ok i dont really know where to put this question at so... i'll start here i have a 99 4 door grand prix GTP and i had problems with the abs and trac light so i got a new abs module from ED and put it on everything worked fine (i thought) well it turns out that my reverse lights dont work and the truck popper doesn't either (on my keyless entry and the button in the glove box) i checked the fuse and it was fine but replaced it anyway just in case and nothing but... this isnt the first abs module i put on i had one that ed sent me and it was crap i put it on and the abs and trac didn't work so i just left it on and a day later my abs module popped like a fire cracker when i tryed to start it so i called ed and he sent me the one i have now that works except the reverse light and trunk thing so if you guys have any ideas at all please let me know
  2. #2 Re: no reverse lights and trunk popper don't work
    GTP Level Member dstout's Avatar
    ky
    I changed my ABS module cause my Trac & ABS lights were on too. I got mine from Ed like you did but I didn't have the problems you are having. I was thinking maybe a bad fuse but you changed the fuses, could be a relay of some kind. There are relays in the fuse box under the hood try looking there.
  3. #3 Re: no reverse lights and trunk popper don't work
    Donating Users
    Plainfield, IL
    the reverse light fuse under the hood is your problem its not in the glove box...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  4. #4 Re: no reverse lights and trunk popper don't work
    Dec 2008
    Manhattan, KS
    the fuse i changed was under the hood #27 slot it was a 10 amp and it controls the reverse lights and truck popper...... if it was a relay which one would it be and where when i hit the button in the glove box nothing at all happens but when i push it on my keyless entry it makes a click on the drivers side like in the side of the dash
  5. #5 Re: no reverse lights and trunk popper don't work
    CT
    try changing the bulbs. I thought I read on here once but blowen reverse light bulbs would cause this to happen?
  6. #6 Re: no reverse lights and trunk popper don't work
    Dec 2008
    Manhattan, KS
    well i give that a shot
  7. #7 Re: no reverse lights and trunk popper don't work
    SE Level Member PontiacGTPSE's Avatar
    Apr 2009
    Jackson, Michigan
    Sorry this doesn't help you, but how much are those ABS module, cause my abs light and my tcs don't work, thanks
    2001 GTP Special Edition
    Mods: Were Getting There...
  8. #8 Re: no reverse lights and trunk popper don't work
    Dec 2008
    Manhattan, KS
    well i got one from ed for 175 but its the whole thing abs pump and module but........ you can send your old one in to modulemasters.com and have is fixed for 200 ish
  9. #9 Re: no reverse lights and trunk popper don't work
    ky
    I paid $175 shipped, dealers wanted $1,200 I think it was more. I bought it from Ed Morad. My computer module was bad can they fix that?
  1. Fog lights don't work
    By spenc938 in forum General Tech Discussion
    Last Post: 06-21-2011, 05:02 PM
  2. 4T65E--No Reverse!!!
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2011, 01:51 PM
  3. Reverse lights
    By KR1ST1N_X3 in forum Visual/Body Modifications
    Last Post: 04-15-2009, 08:10 PM
  4. freakin reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2009, 03:20 PM
  5. reverse
    Last Post: 01-07-2009, 11:23 AM
