okay so i was pulling code p0410 (Secondary Air Injection System Malfunction) so I replaced the smog pump.. cleared the codes.. and the same code came back. When i took the smog pump cover off.. it broke, the cheap plastic just cracked and a chunk came off the side.. i tried sealing it.. but couldn't so the fan is exposed. I can hear the pump turn on so it's working.. but i'm still getting the code.. would the crack in the smog pump cover send this code? I don't think it would.. but i could be wrong.. any help with this trouble code would be greatly appreciated.
