Thread: Smog pump question.. please help.. I'm having so much trouble with this thing.
Results 1 to 5 of 5
  1. #1 Smog pump question.. please help.. I'm having so much trouble with this thing.
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    okay so i was pulling code p0410 (Secondary Air Injection System Malfunction) so I replaced the smog pump.. cleared the codes.. and the same code came back. When i took the smog pump cover off.. it broke, the cheap plastic just cracked and a chunk came off the side.. i tried sealing it.. but couldn't so the fan is exposed. I can hear the pump turn on so it's working.. but i'm still getting the code.. would the crack in the smog pump cover send this code? I don't think it would.. but i could be wrong.. any help with this trouble code would be greatly appreciated.
  2. #2 Re: Smog pump question.. please help.. I'm having so much trouble with this thing.
    Medford, NY
    im not sure how the crack would set off the ses light but if someone knows that it could be the problem please let me know.
  3. #3 Re: Smog pump question.. please help.. I'm having so much trouble with this thing.
    Medford, NY
    i dont think i need the smog pump.. if i'm wrong could someone tell me why? i'm thinking about just plugging the hose and getting the smog pump deleted on the PCM i want to order.
  4. #4 Re: Smog pump question.. please help.. I'm having so much trouble with this thing.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    No, you don't need the smog pump, it's part of the Cali emissions package, most wbodies don't even have them.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Smog pump question.. please help.. I'm having so much trouble with this thing.
    Medford, NY
    i just wanted to make sure i didnt need it.. because some guy was telling me that when it doesnt work. the injectors get clogged and stuff.. it didnt make sense to me at all.. there's no way for it to even effect the injectors.
  1. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
  2. How lame is this thing
    Last Post: 02-17-2009, 12:24 PM
  3. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  4. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
