Thread: car is giving me 5 codes
Results 1 to 17 of 17
97gp97 car is giving me 5 codes 03-22-2009, 04:52 PM
Guest Re: car is giving me 5 codes 03-22-2009, 08:03 PM
97gp97 Re: car is giving me 5 codes 03-22-2009, 08:08 PM
NaturallySmashed Re: car is giving me 5 codes 03-23-2009, 02:03 AM
97gp97 Re: car is giving me 5 codes 03-23-2009, 05:00 PM
NaturallySmashed Re: car is giving me 5 codes 03-23-2009, 11:41 PM
97gp97 Re: car is giving me 5 codes 03-24-2009, 06:19 AM
97gp97 Re: car is giving me 5 codes 03-24-2009, 06:56 PM
NaturallySmashed Re: car is giving me 5 codes 03-24-2009, 10:45 PM
DanGTP Re: car is giving me 5 codes 03-25-2009, 01:02 AM
97gp97 Re: car is giving me 5 codes 03-25-2009, 06:19 AM
NaturallySmashed Re: car is giving me 5 codes 03-25-2009, 12:06 PM
97gp97 Re: car is giving me 5 codes 03-27-2009, 07:44 PM
NaturallySmashed Re: car is giving me 5 codes 03-29-2009, 03:32 PM
97gp97 Re: car is giving me 5 codes 03-30-2009, 03:12 PM
NaturallySmashed Re: car is giving me 5 codes 03-31-2009, 12:05 AM
Quicklynx Re: car is giving me 5 codes 03-31-2009, 12:56 AM
  1. #1 car is giving me 5 codes
    ohio
    P0102-mas/maf
    P0108-map/maf
    P0121-tp sensor
    P0141-o2 sensor
    P1406-some other sensor
    So what do you guys think I should start with, my check engine light has been on for awhile but I never did anything. Do you think all of the sensors just happened to go bad or do you think it could be some other problem? This post caught my eye since it involves some of the sensors so I checked the fuses but they're fine but im not sure which wires to check. So what do you guys think?
    Quote Originally Posted by Reptile View Post
    Check wiring, mainly on your O2 sensor. The TPS, MAF, O2 share a common fuse because they all work together. If a wire is grounding out, it cold blow a fuse as well. Might check in the under hood fuse box I think it's engine cont 1 & 2, location 25-26 or something like that. If you have a Powertuner, you can check your MAF frequency, O2's etc to make sure they look like they're operating like they should. If something doesn't look right, you can start looking there.
  2. #2 Re: car is giving me 5 codes
    TDCRacing
    Guest
    Check the wiring. That seems like an awfull lot to go bad at once.
  3. #3 Re: car is giving me 5 codes
    ohio
    Quote Originally Posted by TDCRacing View Post
    Well like I said The check engine light has been on for quite a long time but I never did anything about it. So I don't know if they all went at the same time or they have just added up. How should I check the wiring, is there a place where they all come together? Or should I just check all of the connections and such?
  4. #4 Re: car is giving me 5 codes
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    if it's been going on for a while then it's possible that those things are messed up man.. fuses are in the engine.. and behind the glove in my car.. if the fuses are good.. replace the tp sensor.. if that code goes away.. then replace the maf and o2 sensor.
  5. #5 Re: car is giving me 5 codes
    ohio
    Ok I just went down to morads and got a tp sensor and map sensor. I will put them in tomorrow and scan for codes and see what happens. Also does anyone know how to go about cleaning the egr valve?
  6. #6 Re: car is giving me 5 codes
    Medford, NY
    take it off.. spray the crap out of it with throttle body cleaner.. watch the gunk drain out... use a gasket maker when putting it back on.
  7. #7 Re: car is giving me 5 codes
    ohio
    ok thanks, I can't wait to sell this thing so I can get a GTP.
  8. #8 Re: car is giving me 5 codes
    ohio
    Ok I put my new stuff on and my check engine light is off so we'll see how long that lasts. I cleaned my egr valve today but im still getting the p1406 code, so does anyone have any ideas on that?
  9. #9 Re: car is giving me 5 codes
    Medford, NY
    you're gunna have to replace the egr man
  10. #10 Re: car is giving me 5 codes
    Feb 2008
    You could just have the EGR disabled and the codes turned off.
  11. #11 Re: car is giving me 5 codes
    ohio
    Well I dont think im gonna even worry about it since im about to sell the car. If it caused the check engine light to come on then that would be a different story.
  12. #12 Re: car is giving me 5 codes
    Medford, NY
    true
  13. #13 Re: car is giving me 5 codes
    ohio
    Well im still getting the p0141 o2 sensor code and I have replaced the sensor twice. The first one I pulled from the junkyard and the 2nd I picked up from morad so I guess theres a possibility they were both bad. I think im gonna need to check over the wiring, any tips or other ideas?
  14. #14 Re: car is giving me 5 codes
    Medford, NY
    buy new lol
  15. #15 Re: car is giving me 5 codes
    ohio
    Quote Originally Posted by NaturallySmashed View Post
    buy new lol
    Looks like thats the case, wiring is good and its also getting power back there.
  16. #16 Re: car is giving me 5 codes
    Medford, NY
    yeah that would be your best bet man. might as well do it before you sell the car.. it would be worth it not to have the SES light on.
  17. #17 Re: car is giving me 5 codes
    Jul 2008
    Germantown, Maryland
    Do 102 and 121 work off each other? If you disable 102 in the tuning software it automatically disables 121. If I turn on 121 it turns 102 on as well.
  1. car is giving me 5 codes
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2009, 04:50 PM
  2. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
  3. Giving Thanks
    By SyntheticShield in forum Site/Club News
    Last Post: 09-11-2008, 03:49 AM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. ecu codes ??
    By sal3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 12:48 PM
