Thread: Daytime running light (DRL) modification help
Results 1 to 18 of 18
  1. #1 Daytime running light (DRL) modification help
    SE Level Member Vinton GP's Avatar
    Jan 2009
    Vinton, Iowa
    I have a basic 2006 GP. This my first car equiped with DRL. I am wondering if there are a few threads are write ups on how to change things around. My first thought is to disable them. Second thought was to wire the function to the parking lights or another set of lights under or behind the grill (I have no fog lamps). Since I leave from the garage very morning the car thinks it is night time. Third thought was to disable the AUTO function and run everything manually like my Taurus (sorry...ex blue oval guy). Ideas? Old threads? Thanks.....Vinton GP (Mike)
  2. #2 Re: Daytime running light (DRL) modification help
    Los Angeles
    I am currently working on this, I've contacted backinblack about it. I have an HID kit I ordered from ebay that I'm trying to put in, so I need the solution to this problem too haha. I've been studying wiring diagrams for our cars, and near as I can tell the BCM controls the DRL automatically. (I haven't checked yet to see if the BCM supplies less than 12 volts to the running lamps , and they seem to be the same brightness as when the headlamps come on. I will check this soon though.) my plan involves wiring a relay into the headlamp circuit using the power feed as an input to a relay, which will provide the headlamp ballasts with 12v directly from the battery. I also plan to wire a switch into the output side of the relay in order to manually open that circuit (to disable the DRL altogether) it is my thought that since there will be a coil from the relay drawing power from the positive side of the headlamp wiring, the BCM will see a complete circuit (even when the DRL's are turned off) and will not register any faults. I will be testing this and will let you know how it turns out. if it works, I can let you know how to do yours.
  3. #3 Re: Daytime running light (DRL) modification help
    Aug 2008
    KCMO
    please do a write up. im wanting HID but this right here is whats holding me back from buying them
  4. #4 Re: Daytime running light (DRL) modification help
    Los Angeles
    my next day off is going to be on tuesday or wed, so I will try and work it all out then.
  5. #5 Re: Daytime running light (DRL) modification help
    Aug 2008
    KCMO
    sounds good keep us updated
  6. #6 Re: Daytime running light (DRL) modification help
    SE Level Member daiadvisor's Avatar
    Dayton, Ohio
    I can't believe that someone somewhere hasn't figured out a way to disable the stupid DRLs. I mean it's elementary stuff. We're not talking about changing engines here.. Sorry - just frustrated.
  7. #7 Re: Daytime running light (DRL) modification help
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    then get on it, firgure it out, its just elementary stuff......
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: Daytime running light (DRL) modification help
    SE Level Member armed's Avatar
    Canada
    Quote Originally Posted by daiadvisor View Post
    lol why don't you figure it out and share?
  9. #9 Re: Daytime running light (DRL) modification help
    Outer Space
    Put headlights on a separate circuit and switch... problem fixed
    02 GTP 13.6 @ 100mph - SOLD
  10. #10 Re: Daytime running light (DRL) modification help
    Dayton, Ohio
    Quote Originally Posted by Lawngoose View Post
    Yeah, but then I'll be getting an annoying "Check Your Headlights" warning on the DIC module all the time.
    I got the Nokya Hyper Purples in there now, it will do until I figure out a way to turn the DRLs off..
  11. #11 Re: Daytime running light (DRL) modification help
    SE Level Member lorenzojay's Avatar
    Roseville Mi
    I just pulled the fuse out and they stay off unless I turn them on.
  12. #12 Re: Daytime running light (DRL) modification help
    Canada
    Quote Originally Posted by lorenzojay View Post
    What about the turn signals? They still work if the fuse is out? and how can you turn them on manually?
  13. #13 Re: Daytime running light (DRL) modification help
    Roseville Mi
    Quote Originally Posted by armed View Post
    yeah the lights stay off unles I turn the knob to use them at night like any other car, the blinkers work fine as well as brights. I have no messages to check anything. I hate haveing the lights on during the day. kills bulb life, Ill be dinking around with the car a lil more after work today cause I just got it lastnight. Its a 97 gt.
  14. #14 Re: Daytime running light (DRL) modification help
    Wausau, WI
    You guys have way different DIC's and the options that it displays on the new ones are way more.
  15. #15 Re: Daytime running light (DRL) modification help
    Roseville Mi
    IM glad its this way, If IM sittin in the parking lot or something listenin to the radio I dont want to have my lights on. its annoying.lol
  16. #16 Re: Daytime running light (DRL) modification help
    Canada
    lol I think your car's DRMs are the normal headlights, on mine , they are the upper part of the fog lights, same bulb as the turn signals that's why I was asking.
    Mine is a 2004 btw
    Thanks for your help anyway
  17. #17 Re: Daytime running light (DRL) modification help
    Wichita
    All you have to do to disable the DRL is remove the fuse in the glovebox. Simple.
  18. #18 Re: Daytime running light (DRL) modification help
    Dayton, Ohio
    On pre-04 models, yes. But mine is an 06 and it's like the holy grail of all mods apparently. NO ONE knows how to disable it.
    Manual override is available of course, but it's so darn annoying.
  1. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  2. How to turn off daytime running light on 2008 GP
    By timc in forum General Tech Discussion
    Last Post: 02-06-2009, 01:51 PM
  3. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
  4. LIM Modification
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2008, 09:20 PM
  5. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
