MSD 31239 Wires New in the Box- 8.5mm:eBay Motors (item 260481441757 end time Sep-28-09 13:18:52 PDT)
on the 3800 i know its for a 8 cylinder but still i think it will work right??![]()
depends on the lengths
yeah im pretty sure length wise should be fine im just wondering do you HAVE to have the striaght insulation boots or does the 90's work also? im in the garage and the 90s do fit fine so ?????????
good point lol but i was just wondering i think the 90degree boots will work fine on the plugs correct?
no they dont so it should be good?
why? why not just get oem ones? there is no performance gain with larger wires.
cuz i know a guy i can get em from for 30 bucks and theyre msd and have nice color and boots are cool loli just hope theyre the right length but i think they would be if not bigger look at the layout of them Super Conductor Spark Plug Wire Set, 8 Cyl 90° Plug/90° Plug - 31229
IF they don't work I would probably buy them from ya for my truck.
lol ok we will see man theyre NEW IN THE BOXso if i cant use them ill sell em for what i paid for em. but i think they will work. i checked the "distributor type boots "basically switch the ignition coil end on the plug wires that i have now and see if they fit and they do. exhaust manifold is sort of close but i think it will be ok.
if i do buy them we will see ha
dont worry im going 3inch catless dp a tune and a 3.4 soon...i already ported my pems
i agree with the tune the pulley the porting work 4inch intake the 3inch zzp dp and the lower tstat and plugs it should be more ballsy
why would i knock.....
