Thread: another downpipe question. (It's on)
Results 1 to 7 of 7
pontiacgp759 another downpipe question.... 03-25-2009, 09:05 AM
FuglyGTP Re: another downpipe... 03-25-2009, 09:53 AM
Bio248 Re: another downpipe... 03-25-2009, 09:59 AM
pontiacgp759 Re: another downpipe... 03-25-2009, 03:12 PM
98SilvermistGTP Re: another downpipe... 03-25-2009, 08:31 PM
pontiacgp759 Re: another downpipe... 03-26-2009, 07:28 AM
Bio248 Re: another downpipe... 03-26-2009, 09:31 AM
  1. #1 another downpipe question. (It's on)
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    Alright i finally got the old dp off with some air tools and have the new one on. only problem is, when i accelerate quickly or floor it, there is a slight hissing noise. My first though is, i have a leak. i took it to an exhaust shop in town and they said they could not find a leak what so ever. Maybe it's such a slight leak that only leaks when there is a lot of exhaust traveling through at once? Maybe the sound is normal? I'd like to hear what you guys think.
  2. #2 Re: another downpipe question. (It's on)
    Nov 2008
    Chicago
    maybe it was a crappy exhaust shop?
  3. #3 Re: another downpipe question. (It's on)
    does it have a flex section? those can cause some noises.
  4. #4 Re: another downpipe question. (It's on)
    Feb 2009
    Ada, OH
    yes it has flex section. i was debating just taking it off and double check myself to make sure the gaskets are all properly aligned.
  5. #5 Re: another downpipe question. (It's on)
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    What brand DP is it? I have an older RT downpipe that ticked and I wrapped header wrap around the flex and it helped alot.
    When you start it up cold do you hear a ticking sound coming from there at all?
  6. #6 Re: another downpipe question. (It's on)
    Feb 2009
    Ada, OH
    no ticking what so ever. I can't even get it to hiss by revving it up in park. Only when its under load when driving can i hear that faint hiss. The DP is from zzp. Also i was curious if there is a right and wrong way to place those gaskets. The one made of sheet metal near the manifold has a side that protrudes out slightly. i put that side towards the dp. and the gasket near the resonator has a thicker side on one part of it. i put that side towards the dp as well. It really stumps me.
  7. #7 Re: another downpipe question. (It's on)
    not sure that you can put the gaskets in backwards or not, but if you can hear a hissing i would think there would be a leak somewhere. im not sure what to tell you besides find the leak.
  1. Downpipe question
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2011, 06:30 AM
  2. anoter downpipe question (gaskets)
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 03-20-2009, 02:07 PM
  3. Downpipe question
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 02-02-2009, 03:43 PM
  4. 3" Downpipe install question
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 07:21 AM
  5. 3" Downpipe question(s)
    By N3p in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2008, 11:54 PM
