Thread: Problem - Can't shut off my vents - 2006
Results 1 to 2 of 2
  1. #1 Problem - Can't shut off my vents - 2006
    SE Level Member Vinton GP's Avatar
    Jan 2009
    Vinton, Iowa
    When I turn the fan to off and drive down the road the air still comes in to the cockpit through the vent ports. I can keep the breeze off me if I close the ports or redirect to the windshield (defrosters). Either way, if it is 60 degrees outside I still need to run the heat a bit because I can't SHUT OFF THE VENTS! Must be something simple I am missing.
    ...can't drive 55 !
  2. #2 Re: Problem - Can't shut off my vents - 2006
    there is always going to be a little air coming through.
  1. Can you shut your lights off?
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-19-2009, 11:45 PM
  2. Car wont shut off!
    By BrokenRhythm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 05:39 PM
  3. Window Vents
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-03-2008, 08:34 AM
  4. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
