Thread: 98 GP stock air filter assembly
Results 1 to 3 of 3
  1. #1 98 GP stock air filter assembly
    GT Level Member hacket's Avatar
    USA
    I just replaced the air filter in my 98 GP SE last week, and am now hearing a kind of 'hollow' sound from that area of the car. When I put the air filter in and connected the tubing assembly back to the filter assembly where the comp is, I couldn't get it to latch on the bottom. Only on the top so it's a little loose on the bottom.
    Is there a latch on the bottom of this assembly? Does it fit securely? Do you think this would create this 'hollow' echo sound?
  2. #2 Re: 98 GP stock air filter assembly
    USA
    Doesn't anyone have an idea? I'll try taking it apart and latching it better tomorrow.
  3. #3 Re: 98 GP stock air filter assembly
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    the filter housing should seal pretty much completely
  1. Steering issues... hub assembly?
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-18-2008, 09:25 PM
  2. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
