Thread: 02 Grand Prix GT Halo Headlights shaking....!
Results 1 to 7 of 7
  1. #1 02 Grand Prix GT Halo Headlights shaking....!
    Calgary
    I bought some Halo headlights on Ebay and they installed painlessly but they shake alot when I am driving...anything I can do to stop that?
  2. #2 Re: 02 Grand Prix GT Halo Headlights shaking....!
    May 2008
    staten island,NY
    yes they shake like a girl with big cans running, there are a couple of right ups on clubgp but i dont think theyre worth it, black ebay lights and HID's are the way to go
  3. #3 Re: 02 Grand Prix GT Halo Headlights shaking....!
    Calgary
    Quote Originally Posted by QwikGT View Post
    Do you know where I can buy a Bounce fix kit for this?
  4. #4 Re: 02 Grand Prix GT Halo Headlights shaking....!
  5. #5 Re: 02 Grand Prix GT Halo Headlights shaking....!
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    i had the same problem when i put them on a car for a friend of mine. if you can find a thick insulating tape like what you would use to seal a door were its like a layer of soft foam, make sure its thick. take out the light and put the tape on the bottomwhen you put it back together it should be more solid. if it still happens you didnt use thick enough insulation.
  6. #6 Re: 02 Grand Prix GT Halo Headlights shaking....!
    Dec 2008
    Lawndale, CA
    The lights bouncing is a common issue with the headlights. There is a write up to limit the amount of bouncing. Some people have said it works and others say it limited the bouncing. As stated weather stripping works as well.
    ClubGP Message Forum troubleshooting
    I also wrapped some electrical tape around the long tab on the projector bracket. That helped a little.
  7. #7 Re: 02 Grand Prix GT Halo Headlights shaking....!
    GTP Level Member dstout's Avatar
    ky
    Yep those are the write-ups I used and I have no bounce,the lights should fit without going thru all the tweeking but.....it's not too hard to fix but still.
  1. Those anybody know if they make projector headlights for grand prix 2004?
    By Whitehispanic in forum Visual/Body Modifications
    Last Post: 01-30-2010, 12:44 AM
  2. Which Grand Prix to buy?
    By porshuh in forum Off Topic Discussion
    Last Post: 02-24-2009, 06:17 PM
  3. 89 grand prix 2.8l.
    By stoney81ta in forum 2.3L Quad 4 (L4)
    Last Post: 02-15-2009, 09:34 AM
  4. shaking when i let off brake
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-07-2008, 06:49 AM
  5. Projector headlights for Grand Prix
    By quakefl in forum General Tech Discussion
    Last Post: 06-20-2008, 12:13 AM
