Thread: Disabling my failing emission code checks for emissions this week
Results 1 to 10 of 10
Quicklynx Disabling my failing emission... 03-22-2009, 11:23 AM
Bio248 Re: Disabling my failing... 03-22-2009, 11:58 AM
Scimmia Re: Disabling my failing... 03-22-2009, 12:10 PM
Quicklynx Re: Disabling my failing... 03-22-2009, 12:15 PM
tylerh Re: Disabling my failing... 03-24-2009, 04:02 PM
Bio248 Re: Disabling my failing... 03-24-2009, 04:04 PM
1998xGTP Re: Disabling my failing... 03-24-2009, 07:23 PM
Bio248 Re: Disabling my failing... 03-24-2009, 07:24 PM
1998xGTP Re: Disabling my failing... 03-24-2009, 07:26 PM
Quicklynx Re: Disabling my failing... 03-24-2009, 07:30 PM
  1. #1 Disabling my failing emission code checks for emissions this week
    Jul 2008
    Germantown, Maryland
    I have to get my emissions done by Friday, 3/27/09 or else my registration will be revoked.
    I haven't been able to fix code P0102. Low sensor circuit frequency to MAF.
    If I disable the emissions codes so I can pass emissions is there anyway they would find out?
    What are the potential consequences if I get caught? Thanks
  2. #2 Re: Disabling my failing emission code checks for emissions this week
    if you disable the codes they wont show up so you will pass, but why dont you just get a new MAF if you need one?
  3. #3 Re: Disabling my failing emission code checks for emissions this week
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Be aware, writing the PCM will cause the emissions test to reset, so they have to rerun, and that could take a couple hundred miles. You'll fail until they complete.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Disabling my failing emission code checks for emissions this week
    Jul 2008
    if thats the case then i will rewrite it tonight and i should be more than fine by Friday.
    Would that work?
    I will be getting a new MAF but funding for repairs are a little tight. im doing fine with the map sensor and im not going WOT so for now im just worried about saving $128 to re-register my car.
    Last edited by Quicklynx; 03-22-2009 at 12:18 PM. Reason: spelling errors due to stupid phone
  5. #5 Re: Disabling my failing emission code checks for emissions this week
    oshawa ontario canada
    where are you located? i know in ontario canada the engine light and codes dont matter for an etest they will still run the test with it on. I used to do them and you might not fail. Over 40% of the tests i did all had engine lights and codes and most of them still passed
  6. #6 Re: Disabling my failing emission code checks for emissions this week
    for those that are skeptical, i just got my emissions tested today and i have no EGR, but the codes turned off. i also dont have a VIN that matches my car in the PCM. i passed without even trying.
  7. #7 Re: Disabling my failing emission code checks for emissions this week
    Dec 2008
    Canada
    That wouldn't pass in Canada
  8. #8 Re: Disabling my failing emission code checks for emissions this week
  9. #9 Re: Disabling my failing emission code checks for emissions this week
    Dec 2008
    Canada
    ...haha!
    Yup I called around and you need the EGR almost 100% of the time, but I have someone on the inside
  10. #10 Re: Disabling my failing emission code checks for emissions this week
    Jul 2008
    Yea all my codes are cleared.. I run a scan on my laptop and nothing comes up.. the SES light is still on however. Last time I failed the SES light was on and they still ran the test.
  1. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  2. emissions
    Last Post: 02-22-2009, 11:56 PM
  3. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
  4. yippie pass the emission test
    By nemesis in forum Off Topic Discussion
    Last Post: 07-04-2008, 03:44 AM
  5. Emission Codes: PowrTuner users
    By fst in forum PCM Tuning
    Last Post: 01-24-2008, 07:44 AM
