Thread: So.......Is it a head gasket
Results 1 to 15 of 15
04BlackComp_G So.......Is it a head gasket 03-21-2009, 08:16 PM
Bio248 Re: So.......Is it a head... 03-21-2009, 08:33 PM
04BlackComp_G Re: So.......Is it a head... 03-21-2009, 08:40 PM
toffog87 gtp Re: So.......Is it a head... 03-21-2009, 09:00 PM
Sabrewings Re: So.......Is it a head... 03-21-2009, 09:01 PM
04BlackComp_G Re: So.......Is it a head... 03-21-2009, 09:05 PM
blowfishRus6 Re: So.......Is it a head... 03-21-2009, 09:06 PM
Sabrewings Re: So.......Is it a head... 03-21-2009, 09:26 PM
blowfishRus6 Re: So.......Is it a head... 03-21-2009, 11:48 PM
Sabrewings Re: So.......Is it a head... 03-21-2009, 11:52 PM
blowfishRus6 Re: So.......Is it a head... 03-22-2009, 12:09 AM
Sabrewings Re: So.......Is it a head... 03-22-2009, 12:30 AM
blowfishRus6 Re: So.......Is it a head... 03-22-2009, 02:19 AM
WhiteDevil Re: So.......Is it a head... 03-22-2009, 07:35 AM
04BlackComp_G Re: So.......Is it a head... 03-22-2009, 04:58 PM
  1. #1 So.......Is it a head gasket
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    I start the car.... It makes a horrible whistling noise and coolant leaks down the side of the engine on to the transmission. Then it abruptly dies..... Is it a head gasket or something else.
  2. #2 Re: So.......Is it a head gasket
    where is the coolant coming from? the whistle could be a big vacuum leak. is your oil milky?
  3. #3 Re: So.......Is it a head gasket
    Apr 2008
    Rockport, ME
    The oil is mixed with coolant, so yes it's milky. It's hard to tell exactly where it's leaking from, but it's only on the driver's side. Now, my evap lines and my vacuum lines are broken and I did post for new ones cause I can't seem to find them anywhere. Would that really cause that leak?
  4. #4 Re: So.......Is it a head gasket
    SE Level Member toffog87 gtp's Avatar
    Jan 2009
    normal IL
    when i just got my vavle cover changed mine was stateing to go there he said its the lower intake gasket(right below the supercharger) i think its the name for it. the guy at gm said its about 750 to replace. cuz they have to take the supercharger off and all that fun jazz. hope this helps ya
  5. #5 Re: So.......Is it a head gasket
    Barksdale AFB, LA
    It's most likely LIM gaskets. They're much more common to fail than the head gaskets and will give the symptoms you describe if they're totally gone.
    2009 Subaru Impreza WRX STI
  6. #6 Re: So.......Is it a head gasket
    Apr 2008
    Rockport, ME
    I'll give it a try again tomorrow. When I reseal them, should I put the RTV in more spots then the corners and the bolts?
  7. #7 Re: So.......Is it a head gasket
    Donating Users blowfishRus6's Avatar
    g.a.
    damn gm is making some money. parts aint but about 100 bucks.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: So.......Is it a head gasket
    Barksdale AFB, LA
    Quote Originally Posted by blowfishRus6 View Post
    Standard labor rates and it's a 5-6 hour job according to the service manuals. Adds up quick.
    All you need to use RTV for is at the corners where the gaskets meet with the block.
  9. #9 Re: So.......Is it a head gasket
    g.a.
    dang there slow.
    it must be nice to get paid 100 something dollars an hour to do something.
    its slow.
  10. #10 Re: So.......Is it a head gasket
    Barksdale AFB, LA
    dang there slow.
    It's not that anybody is "slow". There are standards for how long a job takes. It's all in a database somewhere. Regardless of how long it really takes, the amount of hours they charge you is based off this standardized info.
  11. #11 Re: So.......Is it a head gasket
    g.a.
    yea who ever did it the first time was slow
    again tho must be nice to make 100 dollars an hour to work on a car. to bad the actual mechanic dont see but a small percentage of that
    its slow.
  12. #12 Re: So.......Is it a head gasket
    Barksdale AFB, LA
    But the actual mechanic doesn't have to buy all the tools, lifts, building rental/mortgage, and keep the lights on either.
  13. #13 Re: So.......Is it a head gasket
    g.a.
    true, but thats not going to change my mind on taking my car to the dealership to get worked on. no way in hell is that worth it. i will contuie to buy parts from them tho
    its slow.
  14. #14 Re: So.......Is it a head gasket
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    Labor rate here was $65 last time I checked, that was a few years ago, now I got the warranty I dont have to worry about cost just downtime.
    The oonly reason I go to the dealership mechanic now is the the trust factor and the fact that I know a highly trained person was turning the wrenches on my pig. That and pure documentation. Price sucks but thats why you befriend folks at the dealership, hell it helps even more when a family member is a high ranker at the stealership too.
    Those book times are a *****, I remember working that kind of life. 5-6 hour job in real time was 2-3 MAX
  15. #15 Re: So.......Is it a head gasket
    Apr 2008
    Rockport, ME
    Well, I know what the problem is now. It is the head gasket after all. I started the car and it stayed on long enough for me to get out and see the coolant and oil leaking seeping out of the bottom of the head. Oh well. At least I know what's wrong now.
  1. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
  2. Head Gasket Question
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 11:31 PM
  3. head gasket?
    By Mikefisher in forum General Tech Discussion
    Last Post: 10-10-2008, 12:36 PM
  4. Possible Head Gasket?
    By msmenne17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2008, 10:44 PM
  5. Head Gasket Company
    Last Post: 01-06-2008, 04:32 PM
