Thread: how to remove starter?
Results 1 to 6 of 6
fst how to remove starter? 03-18-2009, 07:44 AM
Scimmia Re: how to remove starter? 03-18-2009, 07:56 AM
fst Re: how to remove starter? 03-18-2009, 07:57 AM
Scimmia Re: how to remove starter? 03-18-2009, 08:51 PM
Abrasive Re: how to remove starter? 03-18-2009, 08:46 PM
Iron Indian Re: how to remove starter? 03-19-2009, 10:16 PM
  1. #1 how to remove starter?
    My starter’s going out on me and I need to know how to take out the old unit and install the new one. I did a few searches and I just need to confirm with those who has done it to agree and/or correct me:
    -Disconnect negative terminal on battery
    -Jack car up and on jack stands
    -Remove the front plastic piece of the dust shroud of the flexplate
    -Remove the 2 15mm bolts-is it just those 2?
    -Heard to be careful not to have the starter fall on you lol
    I understand to disconnect the wires on the 2 contact points but I thought I noticed on the other end(drivers side) there was another wire bolted onto the starter? This is where im stuck. I just ordered a lower mileage starter from ed so that’ll be something I can work on on the weekend. Thanks!
  2. #2 Re: how to remove starter?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Believe it or not, it really is that simple. Just 2 bolts holding it on, and the 2 wire contacts.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: how to remove starter?
    thanks scimmia, but is there also wire(s) connected to the other side-driver's side at all?
  4. #4 Re: how to remove starter?
    QCA, IA
    Quote Originally Posted by fst View Post
    Not that I know of, just the two on the other end.
  5. #5 Re: how to remove starter?
    Odessa, MO
    Most important step right there. It's heavy and hard on the forehead... don't ask, just trust me.
  6. #6 Re: how to remove starter?
    Moore, Oklahoma
    Starter is a piece of cake! Just 2 bolts and couple wire contacts, thats it! Very simple to do. No shims like starters on older vehicles, no shimming required at all.
    And, the starter is definatly heavier than is looks, be careful....
    Shawn W. Larsen
  1. remote starter issues
    By COI in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2009, 11:09 PM
