Thread: service engine soon
Results 1 to 20 of 20
  1. #1 service engine soon
    Feb 2009
    west pittston pa
    i have a 2003 pontiac gand prix gt with 73k.i was out today driving around and i did a little burn out and about a minute later my service engine soon light came on.. any ideas on what mad it come on and wat that could be? mods-zzp ssm90 kit,180 stat, msd 8.55 wires,autolite 103s,3in downpipe with highflow cat,dynomax catback,gtp injectors, zzp pcm tuning for gtp injectors and ssm90 kit, with the m90 code deletes, k&n cai
  2. #2 Re: service engine soon
    Barksdale AFB, LA
    No way to know until you get it scanned. Take it to autozone and have them check the codes.
    2009 Subaru Impreza WRX STI
  3. #3 Re: service engine soon
    Feb 2009
    west pittston pa
    do you think it can be bad or just a pain in the ass code.. just a guess
  4. #4 Re: service engine soon
    Barksdale AFB, LA
    A guess... could be either. Lol, you're asking me to pick a possibility out of several hundred. Just get it checked.
  5. #5 Re: service engine soon
    Feb 2009
    west pittston pa
    k lol im just hoping its nothing bad.
  6. #6 Re: service engine soon
    Feb 2009
    west pittston pa
    is there any codes that are most common?
  7. #7 Re: service engine soon
    Barksdale AFB, LA
    Could be something simple like your gas cap isn't tight, or maybe an O2 sensor. Those are common codes.
  8. #8 Re: service engine soon
    Jan 1970
    Maquoketa, Iowa
    My guess is a 02 sensor code. What are our prizes if we win?
  9. #9 Re: service engine soon
    Feb 2009
    west pittston pa
    idk yet lol, no it came on after i did a burnout
  10. #10 Re: service engine soon
    Feb 2009
    west pittston pa
    lmao my gas cap was off lol someone must of did it thanks ne ways lol
  11. #11 Re: service engine soon
    Barksdale AFB, LA
    So my check is in the mail then?
  12. #12 Re: service engine soon
    Feb 2009
    west pittston pa
    if i had some money i would lol. so im guessing i have 2 get the car scanned 2 get the code off.
  13. #13 Re: service engine soon
    Barksdale AFB, LA
    If you want it off quickly and easily, yes. It will go away on it's own as long as the issue has been corrected. Otherwise you could pull the PCM fuse for about 30 minutes.
  14. #14 Re: service engine soon
    chicago
    does any one know if the service engine light comes on if you have a leak in the boost lines
  15. #15 Re: service engine soon
    Oct 2008
    Northern Illinois
    Quote Originally Posted by bajito View Post
    Not specifically for that but having a vac leak could cause it to run lean which would set a code.
  16. #16 Re: service engine soon
    Oct 2008
    Northern Illinois
    Quote Originally Posted by gp3800t View Post
    I would still get it scanned just to make sure that was the only problem, then you can have them clear the code if it was. Take it to autozone they do it for free.
  17. #17 Re: service engine soon
    A leak in the boost lines? You mean vacuum lines. Sure it's possible.
    My guess on the code is: P009 Lazy owner won't pull a code, probably will blow the motor before he gets it checked out.
    Your car suggested you take a look at it. If something serious is wrong, wouldn't you want to get that checked before it say catches fire, blows up or causes your lazy butt some bodily injury? Sorry for the sarcasm, but "guess that engine light" doesn't sit well with me when parts stores scan for free.
  18. #18 Re: service engine soon
    Guam
    Probably a missfire code.
    I say this because if you got wheel hop, the computer sensed it and threw a code becuase the engine and wheels were not spinning in sync.
    Likewise, if you to hit a pothole, the wheel spins for a nano second and can also cause a missfire code.
  19. #19 Re: service engine soon
    I'm missing something on that one. How does wheel spin = a misfire?
  20. #20 Re: service engine soon
    Guam
    I have heard of it before.
    The PCM uses the rough road information to enable or disable the misfire diagnostic. The misfire diagnostic can be greatly affected by crankshaft speed variations caused by driving on rough road surfaces.
    I believe it has something to do with the vehcile speed sensors as well. If one wheel suddenly spins faster while the other three are moving at another speed, the PCM says hey, something is wrong here.
    I suppose it was like when I had my Vette on the dyno and only the two rear wheels were moving, it set codes.
  1. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  2. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
  3. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
  4. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
