Thread: power window half works?
Results 1 to 6 of 6
  1. #1 power window half works?
    regina
    i have a 97 gp se the rear passenger side window wont roll down i have tried a different motor not attached just hooked to the power leads it will spin one way but not the other i have replaced the rear switch and the master switch and same problem any ideas would be awsome i am stumped is there a relay on these cars and if so where would they be?
  2. #2 Re: power window half works?
    Jul 2008
    sumter,south carolina
    regulator... cables are twisted around inside or something. get a new one for 40 bucks.
    02 GTP with mods 05 GP for DD
  3. #3 Re: power window half works?
    regina
    couldnt be the motor was pluged in but not hooked up to the regulator i was watching the gear spin?
  4. #4 Re: power window half works?
    Jul 2008
    ok so the cable is broke all the way. still the regulator is teh prob.
  5. #5 Re: power window half works?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    My passenger rear will go up and down smooth and quickly, just 75% of the time that you hit the button... not every time... what's up with that?
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  6. #6 Re: power window half works?
    regina
    you missunderstand the motor is new not hooked to the regulator the old motor is hooked to the regulator i just pluged in the wires and it will onlt spin one direction like to roll up but not down?
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Power window issues
    By dbinnc in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2009, 10:04 AM
  3. Auto power window
    By cliffster99 in forum General Tech Discussion
    Last Post: 05-12-2009, 10:17 AM
