Thread: Right signal light flashes fast, left signal flashes normal speed?
Results 1 to 16 of 16
  1. #1 Right signal light flashes fast, left signal flashes normal speed?
    Canada
    I assume a relay or something like that is on the way out.. Are they easy to locate?
  2. #2 Re: Right signal light flashes fast, left signal flashes normal speed?
    Barksdale AFB, LA
    Fast blinking means you have a bulb out on that side.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Right signal light flashes fast, left signal flashes normal speed?
    TDCRacing
    Guest
  4. #4 Re: Right signal light flashes fast, left signal flashes normal speed?
    Canada
    really? that is a handy feature, I will check em out today. Thanks a bunch.
  5. #5 Re: Right signal light flashes fast, left signal flashes normal speed?
    Donating Users blowfishRus6's Avatar
    g.a.
    alot of cars do that. its not just the grand prix
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: Right signal light flashes fast, left signal flashes normal speed?
    Barksdale AFB, LA
    Quote Originally Posted by blowfishRus6 View Post
    Yep. Been that way since the early 90s and probably sooner.
  7. #7 Re: Right signal light flashes fast, left signal flashes normal speed?
    Canada
    None of my previous vehicles have had that feature, got it swapped out today, thanks.
  8. #8 Re: Right signal light flashes fast, left signal flashes normal speed?
    Dec 2008
    Canada
    Quote Originally Posted by nboylie View Post
    Really? I thought almost all had been doing that since like the early 90's?
  9. #9 Re: Right signal light flashes fast, left signal flashes normal speed?
    Canada
    No, but that is understandable, had a '90 caddy and it didn't do it, and a '92 cavalier, and then a 98 truck.. None of them had that feature, it sure is handy though
  10. #10 Re: Right signal light flashes fast, left signal flashes normal speed?
    g.a.
    either the blinker flashes like crazy or it doesent flash at all it just stays lite. alot of cars do that.
    its slow.
  11. #11 Re: Right signal light flashes fast, left signal flashes normal speed?
    GT Level Member black98gt's Avatar
    Rochester NY
    my car does it too, but my rear tail light is still on, just doesnt blink.
  12. #12 Re: Right signal light flashes fast, left signal flashes normal speed?
    Barksdale AFB, LA
    Quote Originally Posted by black98gt View Post
    The rear is probably a dual filament bulb and one of the filaments is burnt out.
  13. #13 Re: Right signal light flashes fast, left signal flashes normal speed?
    Nov 2008
    Chicago
    There is a flasher module on many cars that allows current to flow through a peice of "special metal" that gets hot as current flows through it. When it gets warm it expands. Once it hits a certain temp, it will expand enough so that it breaks the circuit. When a bulb goes out, it changes the amount of current going through the circuit and the expansion/heating rate changes as well.
    Positive side of circuit o--------o "special" wire expands upwards
    Negative side of circuit o----*
  14. #14 Re: Right signal light flashes fast, left signal flashes normal speed?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    The 5-button DICs on the 04+ will for example if you right rear turn signal is out a message will show up that says "Right rear turnlamp out." It will only come up once then the blinker will blink fast.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  15. #15 Re: Right signal light flashes fast, left signal flashes normal speed?
    Nov 2009
    Dallas
    I had the same problem and DIC indication but problem persists even though I replaced the bad bulb, rear right on '06 standard model.
    Any ideas anyone ?
  16. #16 Re: Right signal light flashes fast, left signal flashes normal speed?
    canada
    really? I have known cars to flash fast or stay lit when a light is out for years and years. it is one of my pet peeves to see someone with the front flashing like crazy and the rear nothing. I wonder what that person is thinking? anyway, I realize not everyone knows of that feature
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Front Signal Bulb
    By madmike187 in forum General Tech Discussion
    Last Post: 12-19-2008, 08:52 PM
  3. Signal Lights
    By Fly54 in forum General Tech Discussion
    Last Post: 10-04-2008, 04:24 AM
  4. signal light on 2004
    By blackheart in forum General Tech Discussion
    Last Post: 09-28-2008, 03:07 PM
  5. Turn Signal on Solid
    By coolken84 in forum General Tech Discussion
    Last Post: 08-31-2008, 01:39 AM
