Are grand prix gt's just as good as gtp's and is the supercharger the only difference between gt's and gtp's. Also can you put a supercharger in a gt.
Thanks,josh
Thanks,josh
That depends on the year of cars. The later ones with the comp g package there is a great deal of differance. in suspension, final drive ratio, and i believe brakes.
hahaha
what year of grand prix are you getting?
97-03's about the only difference you will notice is the supercharger and the boost "guage" on the DIC or display in the center. Most of the gtps come with leather seats and the works, but the same is available for the gt's.
04+ there are many differences like what was listed above^^^
The newer grand prixs, some of the gt's are supercharged so there are many packages...
You can put a supercharger from a GTP onto a GT, but it's not as simple as it sounds. To install the supercharger, you'd have to replace everything from the heads up with parts from a GTP (commonly referred to as a top swap). The other way is the ZZP M90 Install Kit, which uses a custom intake manifold to mount the GTP supercharger to your GT heads.
Some major differences:
GT's have higher compression (9.4:1 vs 8.5:1 IIRC)
GT's have higher gearing (3.29 vs 2.93). GTP CompG's, however, have 3.29 gears.
GT's have a different torque converter than GTP's.
GTP's have a stronger HD differential.
Because of these, a supercharged GT will drive differently than a GTP. You'll need more mods to use the same size SC pulley on a GT, but for the same pulley size the GT should be faster due to higher compression and gearing.
you should budget yourself at least $1500 or more depending on if you already have the supporting mods and what gen s/c you plan on running. Your going to need...
-GTP LIM
-GTP Heads & valve covers
-GTP s/c & pulley
-GTP harmonic balancer
-GTP throttle body
-GTP fuel rails
-GTP injectors
-GTP belt tensioner
-GTP coil pack bracket (Im almost positive your going to need the dogbone brakets, not 100% though)
-MAF
-vacume lines
-coolant
-oil & filter
-belt, colder spark plugs, along with all the bolts and gaskets to complete the job.
you going to need some other odds and end pieces that don't come to mind right now...check out the sticky top swap thread. You are also going to need a really good tune in order to run it.
you really shouldn't even think about doing the top swap unless you already have a plog or headers, 180* t-stat, CAI, DP with u-bend delete, and a shift kit wouldn't be a bad idea as well.
My top swap is going to cost in the neighborhood of $2k, but that's because of all the mods I'm doing to it at the same time. I had to buy all the hard parts, plus...
Have the heads reconditioned
LIM ported
SC case ported
TB ported
1.9 rockers
L76 springs
42.5# injectors
Modular pulley system
Plus a lot of miscellaneous little stuff I'm doing. I probably don't hit the full $2k, but since I never actually totaled it up I'm going to say $2k to be safe.![]()
Thats a nice setup, I want to have my heads reconditioned as well. What kind of place did you bring yours to get reconditioned? Im just curious, any reason why your going with the 42.5# injectors vs. the stock gtp 33#'s? Would there be too much injector duty with the 33#'s? I was really debating whether or not to splurge and get the 42.5's.
