Thread: aftermarket fuel gauge wiring
Results 1 to 2 of 2
  1. #1 aftermarket fuel gauge wiring
    SE Level Member momo29's Avatar
    Feb 2009
    bloomington,indiana
    i need help with wiring in an aftermarket fuel gauge(auto meter..etc...)
    here is the problem:when i start my car the fuel gauge needle jumps to full even if it isnt full,it stays there for i little while and then drops to empty and doesnt move again. i am having to use the trip meter to determine how many miles i get to the gallon on an average of 20 mpg. i am tired of doing this and i need help plz.
  2. #2 Re: aftermarket fuel gauge wiring
    I am wanting to make an aftermarket gauge cluster for my GP (which I did for 2 of my older trucks) but the only gauge I am worried about is the fuel gauge, let me know if you get this figured out. I know on the older GM's the fuel gauge ran directly from the sender usually 0-90 ohms to the gauge, now it runs threw the pcm which sends a siginal (most likely 0-5Volts) to the gauge from the pcm, which makes wiring an aftermarket fuel gauge a PITA. I have seen that autometer makes a programmable fuel gauge now, but I dont know if it would work or not. it would be sweet, I already have a gauge cluster layed out already with some gauges, just need the rest including the fuel gauge.
  1. Fuel Gauge
    By agent505 in forum General Tech Discussion
    Last Post: 05-06-2010, 11:07 AM
  2. fuel pressure gauge
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 02:43 PM
  3. 00 GT Fuel Gauge
    By cherm45 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 05:50 PM
  4. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
  5. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
