Thread: ABS and track off lights
Results 1 to 4 of 4
  1. #1 ABS and track off lights
    SE Level Member probuilder1's Avatar
    Jul 2008
    VA
    Well I replaced my passenger side CV shaft about a month ago and my ABS and track off has been coming on and off now it is on all the time. Would you say its a wheel bearing or would it be from somthing I did when changing the CV? Kind of a dumb question but will my ABS still work?
  2. #2 Re: ABS and track off lights
    Jan 2009
    hammond, IN
    i had to change my wheel hub for my car it had the same light problem but after that it was fine, if it is that you will see that how the have the sensor were it is it is in a bad spot and thats why the sensors get mest up
  3. #3 Re: ABS and track off lights
    TDCRacing
    Guest
    Wheel hub(s)
    Also be sure you're posting up in the correct section. That way you're question yeilds the best results.
  4. #4 Re: ABS and track off lights
    I live here. UR LOSN's Avatar
    Rockford, IL
    Moved to Correct Section
  1. went to the track
    By shawn in forum Track Sessions and Kills
    Last Post: 12-05-2008, 11:55 AM
  2. Track ???
    By GTP4 in forum Track Sessions and Kills
    Last Post: 10-02-2008, 08:42 AM
  3. well...so much for the track
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 03:52 AM
  4. So I went to the track right?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 04-05-2008, 11:57 AM
  5. F***** VHT at the track
    By TDCRacing in forum The Rant Forum
    Last Post: 04-01-2008, 11:28 AM
