Thread: No heat -- or very little
Results 1 to 10 of 10
  1. #1 No heat -- or very little
    Dec 2008
    Indianapolis, IN
    I'm semi positive this is an air-in-the-system thing, but it's cold out and we've got no heat in our 03 GT. The car warms up fine and runs great, but heat only comes out when you leave the heater off for 20 minutes of driving, and then only for about a minute. Thoughts? I'm new at this.
  2. #2 Re: No heat -- or very little
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    With the car cool, open the radiator cap. If level in the radiator is low, add coolant to the radiator until it's full.
    Run the engine with the heat on high until it's up to operating temperature and the thermostat opens (you can tell by feeling the coolant hose downstream). Then, open the vent screw on top of the thermostat housing to vent the system. You may have to repeat this several times over the course of a week to get all of the air out of the system.
    Afterwards, recheck the radiator level and refill if necessary. This should remove all of the air from the system.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  3. #3 Re: No heat -- or very little
    GT Level Member njbrain's Avatar
    Rhinelander WI
    You could also try back flushing the heater core.
  4. #4 Re: No heat -- or very little
    Feb 2009
    windsor On
    or check the tstat
  5. #5 Re: No heat -- or very little
    Banned
    Feb 2009
    Wilmington, MA
    ya I would check the t-stat, could be stuck open.
  6. #6 Re: No heat -- or very little
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    if its stuck open the temp gauge will read low temps.
    This is a VERY common GM problem that usually is fixed with a good back-flushing of the heater core.
    If you need a HOW-TO let us know, one of us will post it up. Its fairly simple to do and takes only 10 minutes.
  7. #7 Re: No heat -- or very little
    Feb 2008
    West Jordan, UT
    Quote Originally Posted by WhiteDevil View Post
    I'm not the one with the problem, but I wouldn't mind seeing a how to.
  8. #8 Re: No heat -- or very little
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    is air actually blowing out of the vents? i just had a problem with mine where the heater would only work on the 5 setting.
    SPREAD THE JAM
  9. #9 Re: No heat -- or very little
    SE Level Member BrokenRhythm's Avatar
    Nov 2008
    north plainfield, NJ
    sounds like a clogged heater core
    a flush like mentioned above should definately help it
    97 GTP, Thrasher intake, SLP cat-back exhaust, slp headers, whisper resonator, 3.4 pulley, ssc springs/agx, built trans, 3.29's,ati stall, DHP 1.0, AL 104's, HID's, PRJ wires, 40th interior and hood, 12" brakes, and too much more to list here
  10. #10 Re: No heat -- or very little
    SE Level Member jeffster's Avatar
    timmins
    ya sounds like the thermostate for sure, i had to change mine it was stuck open, the heat would work but once i would start driving eventually the heat would turn cool and fluctuate, i also noticed on my car i had a descent antifreeze leak, the leak would only really show once the engine was under fairly high pressure, the leak would show , not saying thats what it is fill up the rad and definetly check your thermostate there cheap and not hard to change!
  1. heater problems/no heat
    By cartkid14 in forum General Tech Discussion
    Last Post: 12-23-2008, 06:11 AM
  2. Air and heat problems
    By chrizzle17 in forum General Tech Discussion
    Last Post: 12-10-2008, 08:28 PM
  3. 98 Grand Prix GT too much heat NO AC
    By markh in forum General Tech Discussion
    Last Post: 09-25-2008, 10:29 PM
  4. Cut off heat shield?
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:03 PM
  5. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
