Thread: need help!! misfiring???
Results 1 to 7 of 7
  1. #1 need help!! misfiring???
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    I just finished a head gasket change on the 3800 from my '02 GP, did the LIM and a new plenum and gasket. thought I had a vaccum leak because of sputtering, checked that out with some carb cleaner, everything is good in that aspect. just took it down the road and it pops and sputters, any ideas ? thought maybe valve lash? Haynes manual said to torque to specs. is it possible the rods are not seated properly, I can't see how though..
    It seems simple and please correct me if I wrong:
    torque the head
    put the rod guide in
    insert the rods in same place they were in
    torque the rocker arms (in the same place they were in) to spec
    any ideas?
    I need some help guys!!
    __________________
    hydro-powered
  2. #2 Re: need help!! misfiring???
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    did you mess wit spark plugs at all? and dose it do it all the time or just wot ? mabey it could be a broken wirt if you have a muilty meter check them and go from there that can be a big prouble and it is one of the cheapest .....
  3. #3 Re: need help!! misfiring???
    I live here. UR LOSN's Avatar
    Rockford, IL
    sounds like a plug wire is on the wrong cyl..... double check
  4. #4 Re: need help!! misfiring???
    Feb 2009
    Highspire,PA
    I did double check last night , b/c I thought about it too!!!!Its good!!! Now what!!!!
    hydro-powered
  5. #5 Re: need help!! misfiring???
    Jan 2009
    bensalem pa
    are the wires used mabey there is a rissestince proublem in the wires if the wires ar not new try a new set when dose it do it w.o.t? or regular throttle?
  6. #6 Re: need help!! misfiring???
    Rockford, IL
    did you make sure the pushrods were locked into the lifter? how BAD is it popping? does it sound like it wants to come back up through the intake? check each spark plug for hairline cracks...
  7. #7 Re: need help!! misfiring???
    Feb 2009
    Highspire,PA
    I got it fixed! It's the wires, I went out last night to check the firing order and found the order was correct. I then made sure everything was secure. I got up this morning and drove it and it was fine. i guess thats it!! thanks guys!!
    hydro-powered
  1. *HELP*car stutters and feels like misfiring above 50% throttle
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2009, 01:47 AM
  2. misfiring?, hesitating? valve lash?
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2009, 08:03 AM
  3. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
  4. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
