Thread: The Old and The New, Blower Motor Resistor
Results 1 to 12 of 12
  1. #1 The Old and The New, Blower Motor Resistor
    Oklahoma
    After replacing my blower motor resistor, I can see why the OEM ones are so prone to failure. I took some comparison pics so you can see what I mean. I had to superglue the old one back together because I had to break it in order to get it out.
    The Old Blower Motor Resistor:
    The New Blower Motor Resistor:
    The new one appears much better build to deal with and dissipate heat. So Im hoping I dont have to get back under there any time soon. I had been a long time without fan speed #5. Finally, due to the ignition switch, I lost other speeds as well so I just knocked them both out and replaced them both. Its good to have all my fan speeds again.
  2. #2 Re: The Old and The New, Blower Motor Resistor
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    it's kinda funny that you lost 5 first, then the rest... thats backwards!
  3. #3 Re: The Old and The New, Blower Motor Resistor
    Oklahoma
    Yeah, which is why I lived with it so long. I never could get a clear answer as to why that happened that way. Most loose 1-4 and 5 still works. But blessed me, I got the weirdo.
  4. #4 Re: The Old and The New, Blower Motor Resistor
    SW Chicago Suburbs
    mine lost 1-4, like normal... went a few months with just 5...then nada, nothing at all.
    replaced the resistor, and all good all around.... odd
  5. #5 Re: The Old and The New, Blower Motor Resistor
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    mine went without 1, than I lost 5, then I lost the rest...even weirder
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  6. #6 Re: The Old and The New, Blower Motor Resistor
    Oklahoma
    If it werent so blasted hard to get to I would buy another one and do some experiments to find out how that all comes about, but I aint getting back under that dash and fighting with that thing right now.
  7. #7 Re: The Old and The New, Blower Motor Resistor
    SW Chicago Suburbs
    actually, looking at the schematics, it's pretty easy to see how these different scenarios could occur.
    The Old and The New, Blower Motor Resistor Attached Images
  8. #8 Re: The Old and The New, Blower Motor Resistor
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Is that whole unit just one resistor?
  9. #9 Re: The Old and The New, Blower Motor Resistor
    Oklahoma
    They are both complete units.
  10. #10 Re: The Old and The New, Blower Motor Resistor
    Oklahoma
    Is that a fuse between each of the resistors? It does make more sense now seeing the diagram.
  11. #11 Re: The Old and The New, Blower Motor Resistor
    SW Chicago Suburbs
    yeah, it certainly is written that there is a fuse inline with each resistor.
  12. #12 Re: The Old and The New, Blower Motor Resistor
    Oklahoma
    Now thats certainly odd because I see the 4 fuses on the old pack, but not on the new one. There were a couple external devices on the new one (one of them you can see at the top of the pack) and I didnt pay them much attention but I thought perhaps they were diodes to prevent reverse voltage as the motor engaged but I guess they could just as easily be fuses as well. If they are fuses, there certainly was not 4 of them on there.
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. blower motor
    By Chleby in forum General Tech Discussion
    Last Post: 09-13-2017, 04:00 PM
  3. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  4. Motor Trend First Look '09 ZR-1...
    By newfie in forum Off Topic Discussion
    Last Post: 01-23-2008, 07:58 AM
  5. 97 blower motor wont fit a 99
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-01-2008, 12:14 AM
