Thread: Replacing the shifter cable
Results 1 to 3 of 3
  1. #1 Replacing the shifter cable
    PA
    Anyone know how to go about replacing the shifter cable? I got a good used one from Ed. And I have the console apart and the cable unhooked from the shifter. But I can't seem to get it pulled through the firewall. It is getting stuck and I don't want to get yank it out and then not be able to get it pushed back in.
    Anyone have any experience replacing this? Any help is greatly appreciated.
    Thanks guys...
    2001 GSE
  2. #2 Re: Replacing the shifter cable
    GTX Level Member webracin's Avatar
    Arkansas
    On your cable from Ed, it there a molded gromet on it?
    I have never replaced one on a GP, but I have on other pontiacs, and some have a rubber gromet thats molded onto the cable that goes thru the firewall. You may have to pop that out. I know its a real PITA to get out.
    You may want to send a PM to trannyman95 as I am sure he has done a few.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  3. #3 Re: Replacing the shifter cable
    PA
    Thanks for replying.
    But I managed to get it installed. The problem was not the rubber grommet. There was a grommet on the old cable, but not the new. So I used the old one. But the grommet came right out.
    The problem was getting the shifter cable to go in between the floorboards and the plastic vent ducting. I was able to get it out by yanking the heck out of it. It eventually came. And I knew it was going to be hard to get back in so I tired a string to the end of it. When I tried pulling the new one back through, I broke the string. So I had to use screwdrivers, pry bar, and cut the hell out of my hands and arms to get it pushed under the ducting back to the shifter.
    It was a pain in the ass job that I hope to never have to do again.
    2001 GSE
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  3. Short Shifter [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2012, 10:23 AM
