Thread: Replacing the shifter cable
Results 1 to 3 of 3
  1. #1 Re: Replacing the shifter cable
    GTX Level Member webracin's Avatar
    Arkansas
    On your cable from Ed, it there a molded gromet on it?
    I have never replaced one on a GP, but I have on other pontiacs, and some have a rubber gromet thats molded onto the cable that goes thru the firewall. You may have to pop that out. I know its a real PITA to get out.
    You may want to send a PM to trannyman95 as I am sure he has done a few.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: Replacing the shifter cable
    PA
    Thanks for replying.
    But I managed to get it installed. The problem was not the rubber grommet. There was a grommet on the old cable, but not the new. So I used the old one. But the grommet came right out.
    The problem was getting the shifter cable to go in between the floorboards and the plastic vent ducting. I was able to get it out by yanking the heck out of it. It eventually came. And I knew it was going to be hard to get back in so I tired a string to the end of it. When I tried pulling the new one back through, I broke the string. So I had to use screwdrivers, pry bar, and cut the hell out of my hands and arms to get it pushed under the ducting back to the shifter.
    It was a pain in the ass job that I hope to never have to do again.
    2001 GSE
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  3. Short Shifter [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2012, 10:23 AM
