Thread: First Long Trip. Need some help fixing some annoying problems!!
Results 1 to 3 of 3
  1. #1 First Long Trip. Need some help fixing some annoying problems!!
    SE Level Member gpIA's Avatar
    Feb 2009
    Iowa
    So me that Prix are going to Memphis, TN from SE Iowa on Friday. It's our first long haul. Since I'm going to be in her for about 8 and some hours I want things to be smooth and enjoyable. I have a free day on Thursday to spend cleaning and fixing things. I only want to spend about 50 bucks though if I do indeed need to buy anything. Here's some things that bug me and I can hopefully clean/fix...
    1. The ride is bumpy, not sure if I can clean shocks or anything of the sort. Basically just want a smoother ride all together.
    2. Got some annoying plastic ticks...like its flexing or something. Anything notorious in 04+ that rattles and fixable?
    3. My brakes squeak. I have new pads. Tire rod ends are all fine. Although I notice brakes are weak in the pedal but fluid is full...? This bugs me a lot.
    4. I cleaned the throttle body which was HORRIBLE, and now runs much cleaner feeling. Anything else I can get in and clean that will be beneficial to gas mileage, ride, etc.
    Sorry for being so broad. And for such a long post. Thanks for the hopeful help!!
    nik
    2004 GT2
    Maroon, Tinted windows, Focal K5 (18's), K&N Open Cone, Painted tails and tinted reverse bar.
  2. #2 Re: First Long Trip. Need some help fixing some annoying problems!!
    TDCRacing
    Guest
    Quote Originally Posted by gpIA View Post
    nik
    1.The bumpy ride sory to say is more than likley because of the 18's that are on you're car. Or is this something that has gotten worse.
    2. I don't have anything on this one.
    3. Did you put a brake hardware kit on when you did the pads? That is more than likley you're issue. The metal clips is what causes that most of the time. Like 20 bucks for both front tires.
    4. I would clean the air filter and MAF again.
    Hope that helped.
  3. #3 Re: First Long Trip. Need some help fixing some annoying problems!!
    Jul 2008
    Poteau Oklahoma
    change your oil, air filter, check trans fluid, clean your ride inside and out, check and correct tire pressure, dont forget to fill your washer fluid. and many 04+ have squeks and rattles in/on the dash upper/lower. and from what I have payed attention to they all seem to be confined to the drivers area, and if you find your cricket some foam tape should shut it up.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  1. Annoying Door Chime
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2009, 07:54 PM
  2. annoying vibration at 1600 rpms
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2008, 10:14 AM
  3. What tune up's to do before long trip?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 06-22-2008, 09:13 PM
  4. Last minute weekend trip?
    By BabyBlue in forum Midwest
    Last Post: 05-09-2008, 03:56 PM
  5. Just got back from my trip (Pictures)
    Last Post: 04-23-2008, 05:17 PM
