Thread: "Tuned for X deg adv at WOT"...what's that mean?
Results 1 to 15 of 15
  1. #1 Re: "Tuned for X deg adv at WOT"...what's that mean?
    TDCRacing
    Guest
    Quote Originally Posted by DanGTP View Post
    I think what the OP is asking is: If I say I'm running 18* of timing, is that the highest WOT timing value or the lowest WOT value?
    I'll use the picture Parker posted:
    Where he has his WOT values circled, would we consider him to be running 13* or 16*? Or, do we say he's running 15*, since that is close to the average timing at WOT?
    Right that is what he was asking. And the answer would be the highest.
    Typically the number you see will be the number you are running. But there are other factors that you have to consider that advance the timing. Like i said I was seeing right at 22* of timing and looking at the table you don't see any numbers higher than 19.
  2. #2 Re: "Tuned for X deg adv at WOT"...what's that mean?
    Hoffman/Schaumburg, IL
    Quote Originally Posted by TDCRacing View Post
    In hp tuners there are three other tables that add timing:
    Spark Correction
    AFR
    IAT
    ECT
    If you zero these out, then you get whats in the table that was pictured earlier, but if they aren't(which I'd put money yours aren't) then you get the 22* commanded when it only says 16...... With the add tables, stock timing goes up to 20* in some instances
  3. #3 Re: "Tuned for X deg adv at WOT"...what's that mean?
    TDCRacing
    Guest
    Quote Originally Posted by 02BlueGT View Post
    Spark Correction
    AFR
    IAT
    ECT
    Yup that's right.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Inferno Appearance" or 06 "SE Appearance Package"
    By romande in forum Visual/Body Modifications
    Last Post: 04-02-2011, 12:56 PM
  3. 3.5" tuned PCM running on 3.8" engine
    By 04CompG in forum PCM Tuning
    Last Post: 10-06-2008, 05:14 PM
