Thread: Heater/Def/AC
Results 1 to 8 of 8
  1. #1 Heater/Def/AC
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    I've asked this along time ago, but since I read the question titled HVAC, I wonder if we might have the same problem. It's dark out so I'm not gonna go look right now. My heater blows out every vent I've got. I can't switch it around to just defrost or just floor. Could we have the same problem? I hope! I thought mine was a switch or something major($$$). Tomorrow I will look!!
  2. #2 Re: Heater/Def/AC
    Saraland Alabama
    very possible it's the same problem
  3. #3 Re: Heater/Def/AC
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    actually it sounds like the the door acuator is either broke of stuck the if you had a vacumm leak it would be stuck on defrost
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  4. #4 Re: Heater/Def/AC
    Enid,Ok
    It blows alittle out of each vent. I went and looked just now, I can't find what hose they are talking about. Too dark! Guess I'll look at it tomorrow when I fix my window. "Someone" slammed the pass door and the window fell out of the track.
  5. #5 Re: Heater/Def/AC
    Look for a vacuum line that is disconnected or broken under the hood. I drove around for over a year with this same problem....turns out a vacuum line that went to the upper intake was just not connected...just hanging there. I must've disconnected it for something and never put it back. So look for a loose/broken vacuum line under the hood. I had always assumed it would be a switch or something electrical that was causing my problem, but I ended up fixing it in about 15 seconds. Hope that helps!
  6. #6 Re: Heater/Def/AC
    Enid,Ok
    Thanks, I'll look again. I fixed the wiper today It wouldn't go down all the way in the off position. Fixed it all by myself
  7. #7 Re: Heater/Def/AC
    SE Level Member AmericaFcukYeah's Avatar
    May 2008
    This helps a lot! I was just getting ready to post on my climate controls being stuck only on defrost. Tomorrow I'm going to look for a vacuum leak or a disconnected hose. If anyone has any other suggestions please let me know.
  8. #8 Re: Heater/Def/AC
    Dec 2010
    WI
    Did the vaccum hose solve it?
  1. Help!!! My heater died and i live in maine!!
    Last Post: 12-29-2007, 05:43 PM
