Thread: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
Results 1 to 20 of 29
  1. #1 HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    i have no idea what i am doing... ive never done this before.... my mom needs her car back by morning, and its getting dark... i need help so bad right now!!!!!!!! please help me!!!!!!!
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  2. #2 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Jersey
    Intake gaskets?
    16' wrx sti- stock
  3. #3 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Dec 2008
    Freeman, SD.
    yeah, the black plastic things on the lower manifold... AHHH i dont know what to do!!!!
  4. #4 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Jan 1970
    Maquoketa, Iowa
    Run away.
  5. #5 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    depends how far you are already. why did you decide to do it if you didnt know how?
  6. #6 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Dec 2008
    Freeman, SD.
    because im neive and i thought that it would be something like the gaskets on my Acura.... boy was i wrong!! and ive already got the rocker arms and everything mostly off..... im just going to stick it back together, and hope for the best...
    that is if my dad will leave me the **** alone long enough to do it!
  7. #7 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    GT Level Member Preotic's Avatar
    Missoula, MT
    You don't need to take the rockers off for the LIM gaskets.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  8. #8 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Dec 2008
    Freeman, SD.
    i dont fuking care anymore. i cant do this... i give up, i cannot do this. i dont know how, but this has got to go to a mechanic tomorrow..... im just fuking done
  9. #9 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    sorry to hear your misfortune with this, but if you read up on a few threads you should be able to figure it out. the hardest part is the torque sequence.
  10. #10 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Dec 2008
    Freeman, SD.
    i know what to do, i just cant to it... i dont have the knowledge or experience to do it. and now its going to cos my mom alot of money for something that didnt even really need to be done...
  11. #11 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
  12. #12 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Donating Users chrisb's Avatar
    Bucyrus, OH
    if your still doing it or need questions asweared my yahoo messenger is chris_8907 ill help ya out if ya want.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  13. #13 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Feb 2008
    First off, everybody starts sometime and somewhere. It is easy to get overwhelmed when you are not sure and/or haven't done something before. But you got to remember, if you don't know what you are doing and/or not sure, don't do anything until you do more research or get a pal who does know what they are doing to help you out. Starting something and not finishing it and having to admit that you didn't know what you were doing makes you look a probably feel foolish. There is nothing wrong with asking for help or passing on a project that you are not comfortable doing. I'm sure you have learned a lesson with this experience. Remember, as you do more, you will get more experience and more knowledge how do to things. Don't give up, start out dong smaller projects and work your way to bigger ones and you will be doing well in no time.
    Good luck in your future endeavors!!!
  14. #14 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    Donating Users blowfishRus6's Avatar
    g.a.
    remove uper intake, remove lower intake, replace gaskets, put back together. you dont have to touch the valve covers or the rockers, your moving into head territory. remember to use rtv to seal it up or you will just be leaking coolent when you get done.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by 99gpse View Post
    ladies and gentlemen, an excellent display of what panic gets you.
  16. #16 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    go see dubob's vid- I just finished my LIM tonight. Get a haynes manual and look around on the site, all your answers and help are right here. good luck and calm down!!
  17. #17 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    TDCRacing
    Guest
    First off you need to stop.
    Let me ask you something. HOW are we suppose to help you if we don't know where you are at in the process or even what you're doing???
    I understand you may not be too firmiliar with the termonology but you need to try to explain where you are in the process if you do want us to help. I think anyone here is willing to help you as long as we get enogh info for us to do that.
    Are you changing out the upper intake manifold gaskets or the lower intake manifold gaskets?? The intake on top is called the upper and the one on the bottom is called the lower.
  18. #18 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    TDCRacing
    Guest
    Quote Originally Posted by icolex1 View Post
    go see dubob's vid-
    I do not think a newer member that does not even own a grand prix will know where to find that video or even what the hell you are talking about.
    If you really want to help how about posting a link up?
  19. #19 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    TDCRacing
    Guest
  20. #20 Re: HELP!!!!!!!!! IM FREAKING OUT! lost on intake gaskets!!!
    g.a.
    hell newer, i never could find it my damn self. but yes that video explains all.
    and really its very simple. remove upper intake, in my case supercharger, theres the gasket for the upper intake, then remove the lim (lower intake) there is your lower intake, not put things back on the oppisite order you took them off. its really strait forward.
    its slow.
  1. lost hvac control 97 3.8
    By Onthebrinc in forum General Tech Discussion
    Last Post: 02-28-2009, 03:49 PM
  2. Lost Keys... But
    By TMOTA503 in forum General Tech Discussion
    Last Post: 09-09-2008, 07:26 PM
  3. Lost To A Sentra Ser ;9
    By sal3800 in forum Track Sessions and Kills
    Last Post: 07-15-2008, 10:45 AM
  4. lost
    By allenscott292002 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 07:09 AM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
