Thread: Low Coolant Light
Results 1 to 5 of 5
  1. #1 Low Coolant Light
    Feb 2009
    Ogden Utah
    For my 2001 Grand Prix; My Low Coolant Light keeps coming on even though the fluid level is full. Any ideas on where to start?
  2. #2 Re: Low Coolant Light
    TDCRacing
    Guest
    Welcome to the community. Be sure that you are posting in the correct section, That way you will get the answers you need.
    It could be a bad sensor. Make sure you're resivoir is FULL.
  3. #3 Re: Low Coolant Light
    I live here. UR LOSN's Avatar
    Rockford, IL
    Moved to correct area.
    you might just have a malfunctioning level sensor. it is able to be replaced....
  4. #4 Re: Low Coolant Light
    Apr 2008
    Chillin at the Beach , VA
    Pull your low coolant sensor out and clean the end of it off. Over time it will get crud built up on the end and cause it not to read properly.
  5. #5 Re: Low Coolant Light
    Dec 2008
    Lawndale, CA
    Try cleaning the sensor. Mine was doing the same thing. I cleaned it and the light went off. I ended up replacing the sensor after awhile.
  1. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  2. Low Coolant Light...Thermostat?
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 12:03 PM
  3. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
  4. Low Coolant light - bad sensor?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2008, 08:19 AM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
