Okay, since I bought my car, every time I put my foot on the accelerator, I hear this fluid/bubbling sound in the dash. Everyone said it was an air bubble, but my radiator was clogged, so I had the upper and lower radiator hoses replaced, as well as the radiator and thermostat themselves.
The sound remained, but in addition, there's a new problem. My temp gauge says my car isn't heating up past the 140 degree mark (which is below the first big line on the gauge). Someone said to loosen the bleeder valve, so I did that. Then, my low coolant light would go on every once in a while, so I filled the radiator back up.
I ended up overfilling the radiator with coolant, as when it heated up (which is rare), it started coming out of the overflow reservoir (this hole at the top of the neck of this bottle, right under the black cap). I saw a puddle of coolant under my car this morning, but I don't think I'm leaking any - I think it's just coming out because it was overfilled by me.
I tried letting the car run with the radiator cap off, but because of the fact that the car won't heat up to operating temp, the coolant never starts flowing with the cap off.
Then I put the cap back on and tried loosening the bleeder valve. Some air came out, then the car heated up to operating temp. Then, I got straight coolant coming out of the valve, re-tightened it and the fans kicked on.
I took it for a drive and the sound is STILL THERE! With every. single. time. I step on the gas pedal, there's the sound like my car is taking a hit from a bong.
What is going on here?! I'm determined to get to the bottom of this.
Thanks for your help!
