Thread: air fuel ratio ?
Results 1 to 6 of 6
  1. #1 air fuel ratio ?
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    which wire do you tap off of on the oxy sensor , i did the purple and nothing .......help , 97 gt na 3.8
  2. #2 Re: air fuel ratio ?
    it should be the purple wire, you got it right. is the gauge turning on or is it not reading?
  3. #3 Re: air fuel ratio ?
    Jersey
    did you hook it up to a switched power source?
    16' wrx sti- stock
  4. #4 Re: air fuel ratio ?
    Feb 2009
    roanoke va
    yeah its hooked to switched , and hooked to purple and it stays on rich and never moves , anybody got a idea? and my milage is poop only around 16-17 mpg . i have tried everything i know to do , new plugs , coils , wires, new thermostat 195 , put them super turbo replacement mufflers , and from about 3000 rpm and on runs like a scalded dog , and the only code i have on the puter is evap emissions control purge flow , for whitch ive had since ive owned the car . i put a new purge flow valve and it went away for a while but is now back , loosing my mind here , i love the car its got 195,000 and i love the way it handles , so much id love to build a second motor and make it a gtp
  5. #5 Re: air fuel ratio ?
    maybe you are running really rich? have you replaced the front o2 sensor?
  6. #6 Re: air fuel ratio ?
    Feb 2009
    roanoke va
    no but its not throwing a code
  1. 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 04-08-2015, 10:14 AM
  2. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
