Thread: adjusting rear cam angle
Results 1 to 4 of 4
  1. #1 adjusting rear cam angle
    pa
    Chats
    hello, I replaced the rear struts on my 2004 grand prix and the cam angle is off. how do I go about correcting this problem.. I do have the tool to check the cam angle. Thank you.
  2. #2 Re: adjusting rear cam angle
    Chats
    243824
    you can slot the struts or buy camber bolts. they've got a lobe like a cam does to pull or push the strut in or out.
    slotting the struts works best with a carbide die grinder bit. ive done it both ways.
  3. #3 Re: adjusting rear cam angle
    HUDSON
    Chats
    For better camber adjustment in the rear, slot the TOP strut to knuckle mounting holes.
    For the front camber adjustment, slot the bottom "strut to knuckle" mount holes.
    Got to remove the strut from the car to do it.
  4. #4 Re: adjusting rear cam angle
    Feb 2020
    MN
    Chats
    yes, I also have this problenm on right rear only. (07 GP base) 123K MILES, new strut assemblIES today, also have camber adjusting top bolts, but that is not enough for the right side rear. . measured after install of new struts and still off. Am going to remove top bolt and slot strut mount about 1/8th inch, I think that should suffice and get camber same as other side...on a side note, I only get 22k miles out of that right rear tire and inner couple inches of tire was smooth compared to rest of tread that still looked good. other side is almost wearing pefectyly even.
  1. Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    By DnaProdigy in forum Brakes/Suspension/Chassis
    Last Post: 02-07-2017, 11:55 AM
  2. Foglight adjusting
    By GPGT4dr in forum Visual/Body Modifications
    Last Post: 11-17-2011, 02:17 AM
  3. Adjusting tps sensor
    By goldgp in forum General Tech Discussion
    Last Post: 07-18-2011, 01:34 PM
  4. Adjusting rear AJX's
    By SilverToy in forum Brakes/Suspension/Chassis
    Last Post: 11-09-2010, 06:12 PM
  5. adjusting the BBV
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 11:38 PM
