Thread: 2006 Grand Prix GT Some Steering maybe suspension issues.
Results 1 to 3 of 3
  1. #1 2006 Grand Prix GT Some Steering maybe suspension issues.
    GT Level Member mainecrab's Avatar
    Feb 2008
    I bought a 2006 Grand Prix GT from auction with hail damage. Drove it and found had some other issues, no brakes from no fluid, leaking rack and just wandering and not sold on the road. I replaced the tie rod ends and a bad steering rack bushing and that made things better but still it had some floating sometimes like the wheel can go back and forth some without the steering moving sometimes.
    I then replaced the rack thinking maybe something in the teeth since when I flushed it it was leaking it needed to be done and I got a reman rack.
    Got that all in and still some weird feeling. The intermediate shaft I read doesn't really fail just clunk and I greased that up.
    I do need an aligment for sure and somehow the camber on the back driver side is in at the top way too much. I loosened the strut bolts and could move it a tiny but but its way out of whack , but when I check the stuff that would impact that nothing looks out of place. I am wondering maybe a bad bearing itself or of that can be aligned.
    Anything else to try and check?
  2. #2 Re: 2006 Grand Prix GT Some Steering maybe suspension issues.
    being you changed the tie rods, then changed the rack. yes its time to hit the alignment shop. most of them shops will push and pull to test parts before doing the alignment because if theres a bad part, they dont want to be blamed for a piss poor alignment. so they will tell you you need a part if needed. make sure to tell them you just did a rack install. then they know the back story some.
  3. #3 Re: 2006 Grand Prix GT Some Steering maybe suspension issues.
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by mainecrab View Post
    rear suspension control arms, struts, and all that good stuff that keep the rear tires in line.
    08 grand prix NA3800
  1. 2006 Grand Prix GT ABS&Electrical issues
    By Dtrick22 in forum General Tech Discussion
    Last Post: 02-22-2015, 02:23 PM
  2. 2006 Grand Prix Headlight Issues
    By Dre Man in forum General Tech Discussion
    Last Post: 02-08-2015, 07:52 AM
  3. 2006 grand prix issues...
    By AH06GrandPrix in forum General Grand Prix Discussion
    Last Post: 09-08-2012, 07:02 PM
  4. 2006 pontiac grand prix steering issue
    By AZAALGMONLY in forum General Tech Discussion
    Last Post: 04-01-2011, 09:50 AM
  5. 2006 Grand Prix GT Vibration in steering wheel
    By 04montess in forum Brakes/Suspension/Chassis
    Last Post: 09-12-2010, 03:58 PM
