Thread: OBD blue tooth connector for Torque Pro to read ABS
Results 1 to 6 of 6
  1. #1 OBD blue tooth connector for Torque Pro to read ABS
    Jan 2021
    Ohio
    I have this connector.
    Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light https://www.amazon.com/dp/B005NLQAHS...ing=UTF8&psc=1
    I understand Torque Pro will read ABS.
    Using Torque Pro, and the above connecter, it tries to communicate to read ABS, but won't.
    I thought I read on here that connector won't work for ABS.
    Do you think it is the blue tooth connector I am trying to use?
    Is there a blue tooth connector that will allow me to read ABS codes, using Torque Pro, or a different App that will read ABS codes, using the connector I have?
    I have a 2001 Grand Prix SE.
  2. #2 Re: OBD blue tooth connector for Torque Pro to read ABS
    ChevroSys Scan Lite - Apps on Google Play
    install this app, scans everything, abs, srs, p, u and c codes. does live data too. will clear abs history so you can see what code pops back up first. cause you might have 20 codes stored in there from over the decades.
  3. #3 Re: OBD blue tooth connector for Torque Pro to read ABS
    Jan 2021
    Ohio
    Actually, I did try that app a while back, it tries to connect, but won't.
    I don't know if it's my adaptor?
    I thought I read on here, this adapter won't read ABS?
  4. #4 Re: OBD blue tooth connector for Torque Pro to read ABS
    Quote Originally Posted by mrbreezeet1 View Post
    Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light Amazon.com
    that bafx should work fine. that app is a bit of a pita to get to connect. iirc, open the app first, then plug in the bafx. then tap the blue tooth icon up top the screen.
    might need to enter the unlock code for the bafx. most are 0000 iirc. should be in your directions.
  5. #5 Re: OBD blue tooth connector for Torque Pro to read ABS
    Jan 2021
    Ohio
    Ok, thanks, I'll try again.
  6. #6 Re: OBD blue tooth connector for Torque Pro to read ABS
    Jan 2021
    Ohio
    Great! Thanks!
  1. Blue tooth Knock gauge questions
    By GTPNovak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2016, 10:31 PM
  2. Volume in car low when I use blue tooth
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 01-22-2015, 03:35 PM
  3. Replies: 220
    Last Post: 03-22-2013, 07:59 PM
  4. 3.69 gears with 30-tooth (stock) reluctor wheel
    By DuBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2011, 12:15 AM
