Thread: Stalling on highway! P601, P606, U107 codes. PCM?!
Results 1 to 5 of 5
  1. #1 Stalling on highway! P601, P606, U107 codes. PCM?!
    May 2016
    Minneapolis
    Chats
    Car has stalled 3 times in the past few weeks. Always cruising 70mph down the highway. Pull to the shoulder. Sit for 30 seconds. Turn key and it starts up and drives fine.
    Is there anything I should be checking/inspecting? Intermittent PCM wire corrosion or short? Clean with electrical contact cleaner?
    A Crankshaft sensor wouldn't throw these 3 codes, right? Will take any help I can get!!!
  2. #2 Re: Stalling on highway! P601, P606, U107 codes. PCM?!
    Donating Users
    Aug 2021
    Rochester, NY
    Chats
    Here's an old thread with the same codes. He replaced the PCM.
    Car dies randomly and throws codes P0601 P0606 U0107
  3. #3 Re: Stalling on highway! P601, P606, U107 codes. PCM?!
    Donating Users
    Aug 2021
    Rochester, NY
    Chats
    I had weird electrical issues once where I would lose all power while driving. No codes. The wire harness for the cam sensor was out of its channel and touching the crank pulley and it went through the insulation.
  4. #4 Re: Stalling on highway! P601, P606, U107 codes. PCM?!
    Donating Users
    Aug 2021
    Rochester, NY
    Chats
  5. #5 Re: Stalling on highway! P601, P606, U107 codes. PCM?!
    May 2016
    Minneapolis
    Chats
    Thanks FastL67. I'll open up the airbox and inspect the PCM wiring and connectors.
    I am just wondering if anything other than a bad PCM could throw these codes like bad ground(s), bad wires, etc.
  1. 5* of Kr on the Highway?
    By chris99gtp in forum General Tech Discussion
    Last Post: 05-17-2015, 03:25 AM
  2. 2006 Pontiac stalling driving down highway!
    By Vinson clark in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2013, 04:34 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. Gtp on the highway
    By Ultra440 in forum Track Sessions and Kills
    Last Post: 07-16-2012, 02:16 PM
  5. Stalling - no DTC codes
    By Rico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2009, 07:38 AM
