Thread: No Dash or Tail lamps
Results 1 to 2 of 2
  1. #1 No Dash or Tail lamps
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Chats
    127
    2002 GTP and both dash and tail lamps are out, while turn signals and headlights work. The "lights on" chime also dings whenever the door is open regardless if lights are on or off. I unplugged and re-plugged the headlamp switch and the problem went away! Everything worked normally and I chalked it up to a loose or corroded connector. Then the car sat overnight and the next day the same problem is back. No amount of wire-wiggling has any effect. I even got a new headlamp switch from the JY and no change. ideas?
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  2. #2 Re: No Dash or Tail lamps
    Dec 2008
    ****'s Creek
    Chats
    127
    Problem identified: The orange wire coming from the tail lamp fuse in the underhood fuse box was loose. That seems to be the fix.
  1. Tail lamps
    By CHEVYMAN434 in forum Visual/Body Modifications
    Last Post: 07-28-2012, 11:00 PM
  2. tail and dash light problem
    By GTPSHAWTY in forum Visual/Body Modifications
    Last Post: 07-23-2012, 02:17 AM
  3. Need Help/Suggestions on Stop(Brake)Lamps/Interior Lamps/Cig. lighter.
    By Bulletproof Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2011, 01:51 AM
  4. tail lamps have moisture
    By bmwdriver in forum General Tech Discussion
    Last Post: 10-19-2009, 10:52 AM
  5. L.E.D Tail lamps
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-09-2008, 05:34 PM
