Thread: Fuel trims off
Results 1 to 5 of 5
  1. #1 Fuel trims off
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    I am having issues with my fuel trims being off. There are no exhaust leaks, the o2 sensor is new, and I can not find a vacuum leak. The MAF is a “newer” Delphi. Probably about a year old. What am I missing? Maybe a bad MAF but the readings seem ok. I tried to tune the trims but they keep going off. They are all over the place. Any suggestions?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Fuel trims off
    Chats
    83662
    They are off how?
    Low or high?
    Is fuel pressure good all the time?
  3. #3 Re: Fuel trims off
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    They are low and high. It fluctuates.
    I have tested fuel pressure and it is good but I did not test it over a period of time. I am running an AEM high flow pump.
  4. #4 Re: Fuel trims off
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    I have an AC Delco Maf on order just in case. I will have to get some recent scans and figure out how to post them here.
  5. #5 Re: Fuel trims off
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    I cleaned off the MAF again and the trims seem to level out. I am thinking the METH injection may be messing with it. I adjusted the meth so it doesn't inject at a lower boost. So far it is running better.
  1. sort out fuel trims
    By 04lss in forum PCM Tuning
    Last Post: 07-25-2019, 06:32 AM
  2. getting fuel trims dialed in
    By Timing in forum PCM Tuning
    Last Post: 04-21-2013, 10:13 PM
  3. -20% fuel trims on stock engine?!?!?!
    By jdmgtp in forum PCM Tuning
    Last Post: 07-08-2012, 03:31 PM
  4. Fuel trims
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-11-2011, 01:55 AM
  5. Help with fuel trims
    By 00gpgtp in forum PCM Tuning
    Last Post: 01-10-2009, 11:48 PM
