My car had started stalling. Crank no start. After awhile it would start back up run for awhile then do it all over again.
I want to say it's the cps. Before I pull the balancer and replace the sensor I checked my wiring.
1st two pictures are at the harness 2nd two are at the sensor connector.
Basicly if this is normal I'll go ahead and change the sensor.
At the connector the test light is very dim
Off topic my oil pan gasket is leaking some. Is it a good idea to change it while the balancer is off?
Sent from my SM-N920V using Tapatalk
