Thread: alternator upgrade
Results 1 to 12 of 12
  1. #1 alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    Seems that someone discovered that a denso 104210-4360 is a good swap for this car.
    Also a 08 up impala swaps
    Not sure if this info is new here, but here you go.
    11180 -
    Looks like it was in a lucerne.
    just need the regulator converted.
    Info, Might already be out there if someone has the time to look.
    these are the oem numbers
    20757890
    20911162
    25764632
    Alternators - Pontiac - Grand Prix - 3.8L - 2005 - 2008 - Mechman Alternators
    feel free to add to this or take away.
    not saying it is right or wrong.
  2. #2 Re: alternator upgrade
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    What is the benefit to this?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #3 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    My guess is that mechman determined it was the best to turn up the amperage inside of to 240, also seen some 150 amp alternators for the 08 impala , police duty you know.
    It is a Frankenstein thing I ma sure some parts from here some from there,
  4. #4 Re: alternator upgrade
  5. #5 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    ACDelco 150 Amp Alternator - New
    Part #: 15846253 Line: ACD
    No rating value for ACDelco 150 Amp Alternator - New (0)
    Check Vehicle Fit
    Select a store to see pricing & availability
    Search for a store page input 7
    City & State or Zip
    FIND
    When autocomplete results are available use up and down arrows to review and enter to select. Touch device users, explore by touch or with swipe gestures.
    Alternator New; 150 Amp (KG4)
    New Or Remanufactured: New
    Amperage (A): 150 Amp
    Pulley Belt Type: Serpentine
    SHOW MORE
  6. #6 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
  7. #7 Re: alternator upgrade
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    Don’t see many cases to where this would be worth the trouble.
  8. #8 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    alternator upgrade-screenshot_20200919-221301-jpg
    alternator upgrade Attached Images
  9. #9 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    alternator upgrade-screenshot_20200919-221639-jpg
  10. #10 Re: alternator upgrade
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    How hard would it be to fix the regulator? I can think of no circumstance where I wished I had less current, and many where I needed more
  11. #11 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    I do not know, I am sure, it is all off the shelf stuff.
    I will make a few more pictures between now and next week of the Mechman installed.
    It is tight.
    And I see no numbers on it to give a clue.
  12. #12 Re: alternator upgrade
    Nov 2014
    Macon, GA
    Chats
    Also mechman sells that small diameter pulley cheap.
    Might be a good start.
  1. CS144 Alternator Upgrade
    By Booba5185 in forum How To Write-Ups/Tech Tips
    Last Post: 10-09-2017, 10:32 AM
  2. Rear Brake Upgrade Junkyard GXP Upgrade Compatibility Question
    By wstefan20 in forum Introductions/Noob Questions
    Last Post: 09-18-2017, 04:56 PM
  3. 04+ HUD, HD Trans Upgrade and ZZP Alternator Relocation
    By Explicit_Spade in forum For Sale - Parts
    Last Post: 11-14-2013, 06:13 PM
  4. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  5. H. O. Alternator
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2011, 09:26 PM
