Thread: Any input on this data log from yesterday?
Results 1 to 20 of 25
  1. #1 Any input on this data log from yesterday?
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    My number 6 Cyl now has a misfire issue, but I know for a fact that it is the fuel injector. there is some negligible misfiring in a couple of the other cylinders (maybe a 2-4 count periodically), but my map readings are significantly higher when #6 is going apey.
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  2. #2 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    enh.....disregard HTML fail above. Datalog can be viewed here
    99 GTP:
  3. #3 Re: Any input on this data log from yesterday?
    your car needs lots of help. trims are all over the place, kr starts when it goes lean, misfire city on 6 like you said.
  4. #4 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    Right, and part of the problem is that I still need some sort of tune at this point, I believe. When I replaced the snout, the pulley that came with it was a 3.4, and I'm not overly excited about driving around without a tune at all. Trying to baby it on the rare occasion that I have to drive it, and fortunately that's not often. How much of this will clear up with, say, an Intense canned tune, do you think? As much as I want to justify it, an hpt is def. A little ways out.
  5. #5 Re: Any input on this data log from yesterday?
    tune cant fix these issues. you need to fix the misfires and injectors first or you'll never run right.
  6. #6 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    Replacing that and one other injector, and they will all be new. That will clear up the high count misfire on the # 6, and I guess I'll go from there. I just wasn't sure if the lack of tune was contributing in any way.
  7. #7 Re: Any input on this data log from yesterday?
    im sure most of that knock is from one cylinder being lean. cause you got kr when your hardly in the gas.
    looks like your set to 15º wot, thats stock on most cars, 97-03.
    as long as you have headers or a at least a 3 inch down pipe you should be ok on the stock tune. stock manifolds and stock dp wont work out so well.
    and after you fix all the issues and its running better if you still have kr a set of rockers could really aid in getting rid of a few degrees of kr. my car had 8 bone stock, no tune. rockers killed off 5 degrees of kr, then a u bend delete killed off the last 3 i had. that was a stock pulley tho. but my car was also clearly a kr monster.
  8. #8 Re: Any input on this data log from yesterday?
    The Boss Iceman6669's Avatar
    Jun 2011
    Scotty is right on the money...
    You CAN NOT tune around mechanical issues. EVEN if you tuned your car right now, after you fix your issues your tune would be way outta whack.
    Fix the issues FIRST then worry about a tune.
    Im willing to bet that most of your KR is due to the misfire and fuel being wasted.
    Misfires make your FTs see a lean condition since they are seeing a butt load of unburnt air.
    2011 F-150 Yote powered
  9. #9 Re: Any input on this data log from yesterday?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    a 3.4 pulley on a stock tune is enough to peg the LTFT to 16.4% even without misfires.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    The only thing that made me think that *maybe a tune would help at all, other than the smaller pulley, is the fact that none of this happens until I've been out driving, then stop, and start the car again. Obviously that injector needs to be replaced, and I should have been more clear, that is happening asap regardless, but I don't see any misfires until heat soak sets in. I have a fresh water pump and colder tstat (180), but I figure with the fan controls modified to (hopefully) control underhood temps a little better, maybe that would help remove the other occasional misfires that happen after heat soak.
    1st things 1st though, and I'll go from there...
  11. #11 Re: Any input on this data log from yesterday?
    truth be told, that 185 t stats not helping a damn thing. fans tuned or not, your engine will still hit and break 200º in summer heat.
    i ran stock 195 and tuned fans, it would always reach 200. and the engine runs best at 200. not cooler. its was made to run that hot.
  12. #12 Re: Any input on this data log from yesterday?
    Jun 2011
    Oh yes.. The age old argument of does a cooler TSTAT help or not. Some say it does, some say it does not. It really boils down to who you want to believe. I personally ran a 180* and saw cooler operating temps once I tuned the fans correctly. BUT not everyone agrees. The concept was all about keeping the water jacket a touch cooler to help cool off the ICT. Just my input on it.
  13. #13 Re: Any input on this data log from yesterday?
    my ss has 160, it hit 225 on a 100 degree day. tans are tuned ect ect....
  14. #14 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    So it will likely be the weekend or next week before I am able to replace the last couple of injectors, so as an experiment, I decided to attempt some creative underhood temperature control, just to see what happened. I had read somewhere about someone being able to temporarily reduce underhood temps by placing aluminum foil in some specific places. While I didn't anticipate really reducing radiant heat, I figured maybe I could prevent some of the heat soak that is at least a factor in my issues. I put a few layers of foil between the crossover and the TB, and placed a 3 or 4 ply rectangle between the #6 area of the fuel rail and the EGR. Janky setup? Absolutely. Effective? Sort of! I keep forgetting to add coolant temp back to my data log, but just from the occaisional spot check on live data, I saw it hit as high as 221, and average was 204-ish during this particular drive. Even knowing that there is an issue with the #6 fuel injector, it did not count anywhere near as many misfires as it did in the previous log. My LTFT's seem to start fluctuating more as the car gets warmer, so I still need to figure out what's going on there, but from the aspect of it behaving better while a little cooler, it seems like fan adjustments would help (at least a little). Anyway, see new .xls readout HERE ​.
    99 GTP:
  15. #15 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    -since I can't edit.....maybe all I need is more reynolds wrap in my life! lol
    99 GTP:
  16. #16 Re: Any input on this data log from yesterday?
    May 2008
    Schuyler, NE
    I made a couple more hp on the Dyno at 180° coolant temps than I did at 195-200.
    I like the 180 because it will usually keep the transmission a bit cooler.
  17. #17 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    New Injector and another set of o- rings will be here some time tomorrow, and I'll probably get those put on Saturday. Curious to see what the logs look like then, but that's a start.
    99 GTP:
  18. #18 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    Latest data log. All injectors and O- Rings are new, and the bulk of the misfires are gone. Still looks like I get some occasionally, but nothing more than a 2 count, and nothing noticeable. I'm going to start with checking plugs once I can get a consistent fix on where the misfires are. As far as LTFT's, they are largely high negative numbers at idle, Implying that I'm running rich (-16.4 + in some cases). I have not thrown a code of any sort since the last injector was in, but the high LTFT's concern me. Also, it seems like I am seeing a little more KR with that particular issue fixed. I see my B1S1 o2 has some really low readings at times also (<10 mV), so I'm wondering if the O2 is symptomatic of the LTFT issue, caused by some other, yet undetermined factor, or the other way around, that the LTFT is because of an out of spec o2. Also, Maf g/s readings are a little high at idle, but I attribute that to the smaller pulley. What do you guys think? Other than what the data logs are telling me, it feels like it's running great.
    99 GTP:
  19. #19 Re: Any input on this data log from yesterday?
    your scanning the o2 in volts, all it does is dance up and down, thats normal. you want to scan it in MV.
    the high neg litfs could be a stuck open injector, maybe the one you just put in.
  20. Likes ThatOldCarSmell liked this post
  21. #20 Re: Any input on this data log from yesterday?
    Apr 2020
    Upstate SC
    Welp, back to the drawing board, I guess. At least it's driving better. Another sign of a stuck injector would be difficulty starting after sitting for a while, yeah? I don't have that going on, but I recall reading something to that effect. Any other symptoms to look for that would indicate a stuck/ sticking injector? And I'll be a little livid if brand new injectors with maybe 500 miles on the oldest of them are sticking.
    99 GTP:
  1. Replies: 9
    Last Post: 08-15-2016, 04:25 PM
  2. All Data - Questions Welcome
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 07:25 PM
  3. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  4. Obd live data ?
    By DC1263 in forum General Tech Discussion
    Last Post: 03-24-2009, 10:42 AM
  5. I got my 18's on yesterday!
    By xbnb1978x in forum Tires & Wheels
    Last Post: 10-23-2008, 09:37 AM
