Thread: 2004 GP Starting Issue
Results 1 to 3 of 3
  1. #1 2004 GP Starting Issue
    Dryden
    My 2004 grand prix has developed an issue with starting. I am told that it has spark, fuel and cranks over but will not start. Any ideas what might be causing this issue. It was running good and then all of a sudden it has stopped. Any help would be greatly appreciated.
    Brett
  2. #2 Re: 2004 GP Starting Issue
    St. Louis
    If it has fuel then it should at least try and run. I would start with the basics and check ALL the fuses underhood and inside.
  3. #3 Re: 2004 GP Starting Issue
    I would run my own tests. A fuel rail can have fuel going to it, but is it being injected into the cylinder? Listen to the injector when the key is turned to on, you can always use something to amplify the sound like a screwdriver held to your ear to test these. Spark is an easy one to test. And...I'd question what "cranks over" actually means. The motor should sound normal like any average start when it's cranking over.
  1. Starting Issue
    By Bronco Boy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2016, 09:04 PM
  2. New guy with a starting issue
    By dmj in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-17-2014, 09:20 PM
  3. Please someone help me out here, starting issue.
    By Brickie in forum Off Topic Discussion
    Last Post: 01-09-2012, 12:30 PM
  4. 97 Gtp starting issue
    By DukesGTP in forum Off Topic Discussion
    Last Post: 10-29-2010, 06:35 PM
  5. 04 starting issue
    By peppy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2010, 02:45 AM
