Thread: low voltage
Results 1 to 6 of 6
  1. #1 low voltage
    Jan 2018
    Canada
    Hi,
    On a 2007 Grand Prix base, the battery is around 2 years old, and randomly I would see like 12.4 v under load, accessories on, while idling. Other times it would be in the normal range. Sometimes it go up to 13v range. Recently the alternator was outputting low and noisy under load and randomly, so I had it changed. The new alternator the car runs better, and randomly it will drop while under load, and other times it will be normal in the 13v range. I checked the voltage drop its about 0.4v difference.
    I did read online and even on this forum, that sometimes the wire harness for the alternator could an issue, I saw that in a recent post. And something about GM's charging system, but I don't know if this applies to the Grand Prix.
    I did check some other things, cables are clean, tight, belt is original.
    Please let me know.
  2. #2 Re: low voltage
    St. Louis
    So you have an OEM 13 year old belt on it? If so this would be the first thing I would change out and then go from there.
  3. Thanks hijanek thanked for this post
  4. #3 Re: low voltage
    Jan 2018
    Canada
    Thank you Fordman77, I could look into it.
  5. #4 Re: low voltage
    Jan 2018
    Canada
    The new belt is on and its about the same voltage. Thank you.
  6. #5 Re: low voltage
    GTP Level Member
    Oct 2014
    I believe the grand Prix’s have a variable voltage that cycles from 12.x to 14.x during a drive. I drove 2 different ons for years and they botje did this on my 55 mile drive to the office. Never had an issue.
    I would say Normal.
  7. Thanks hijanek thanked for this post
  8. #6 Re: low voltage
    Jan 2018
    Canada
    Thank you Markpa.
  1. MAF Low Voltage
    By 02GTPJeff in forum General Tech Discussion
    Last Post: 01-29-2016, 08:02 AM
  2. Low Voltage
    By akarana23 in forum General Tech Discussion
    Last Post: 07-14-2013, 10:00 AM
  3. low voltage
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 10:19 PM
  4. No Voltage at PCM
    By tdenstedt in forum Introductions/Noob Questions
    Last Post: 04-22-2011, 09:08 AM
  5. Low Voltage
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 02-12-2011, 03:24 PM
