Thread: Instrument panel trim clips
Results 1 to 6 of 6
  1. #1 Instrument panel trim clips
    Jul 2020
    Abbotsford, BC
    So I discovered a lot of the clips are missing from the trim that run around the instrument cluster and radio.
    The dealer has not been helpful here, does anyone know a part number for these little metal clips?
  2. #2 Re: Instrument panel trim clips
    St. Louis
    Not sure on the GM part number but if you can measure on of the existing ones you can likely find it at a parts store or Ebay. Worst case hit up a junkyard and snag a few.
    My question would be are the plastic tabs on the cluster bezel still in place to install the clips. I've pulled a few over the years and noticed that someone was in there before me and snapped a few off.
  3. #3 Re: Instrument panel trim clips
    Jul 2020
    Abbotsford, BC
    Well I found what looks like the clip and the aftermarket discontinued them.
    I look to be lucky, all the tabs were there. I've rearranged the clips for now so that there's support in the corners. Unfortunately there's not a lot of pick and pull wreckers left here any more.
  4. #4 Re: Instrument panel trim clips
    St. Louis
    If you can show me a pic or link to a pic of one I may have found a source for them. I can't remember what they look like and don't want to pull my bezel to check
  5. #5 Re: Instrument panel trim clips
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I have 3 of them, if you want the DM me your address and I'll put them in an envelope and drop in the mail.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Instrument panel trim clips
    Jul 2020
    Abbotsford, BC
    Thanks for the offer! I've already put the panel back in place.
    I decided to be "clever" and make sure the corners at least have anchor points. I didn't have to to wander around a wrecker, and around here I think there's only the one that has a GP, and it's the the part of the yard where you can't help yourself to parts.
    I've been driving it for a week and nothing is squeaking, so I'm just gonna shrug my shoulders and call it fixed.
    I was concerned about squeaks with missing clips as I've had that problem with my other cars.
  1. Replies: 0
    Last Post: 08-06-2013, 06:12 PM
  2. Replies: 0
    Last Post: 08-06-2013, 06:09 PM
  3. Instrument Panel Out!!!!!
    By Torell10 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2012, 01:53 PM
  4. 04+ Instrument panel in 97-03
    By nebgrandprix in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2011, 04:11 PM
  5. Instrument Panel
    By iceman977th in forum Visual/Body Modifications
    Last Post: 12-23-2010, 04:04 AM
